Portable Car Heater
footyste123
Portable Car Heater
Post by footyste123 » Tue Dec 14, 2010 10:50 pm
Has anyone tried using a portable car heater that plugs into the cigarette lighter (Front Heater Fan in Bongo is tempramental!!!!!). I tried one that was for a 12v DC cigarette lighter socket (15 amps or higher) and it blew my fuse. Any ideas?? Anyone know a make that does work in a Bongo??
Re: Portable Car Heater
Post by missfixit70 » Tue Dec 14, 2010 10:58 pm
Pop into Thorntons & get them to make you a chocolate fireguard, it'll be more use. 12v heaters just won't cut it due to the power needed. If you need it go for a mains heater, diesel heater such as eberspacher or webasto, or a propex heater, Plenty of recent threads.
Bongo heater works great when it works right, what's temperamental about it? FAQ here may help - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727 - it may be an indicator of more serious issues than an iffy heater, ie coolant system issues, get it checked out.
Post by g8dhe » Tue Dec 14, 2010 11:02 pm
The cigar lighters are really only good for about 10Amps Max. and even then you will suffer at least 0.5 volt drop possibly 1.5volts so you may get only about 12 volts even with the alternator running - this means that you will have a 120Watt heater which really isn't a lot at all, personally I wouldn't even bother.
If the heater is intermittent then you may just find that its one of the connectors that needs pushing home - which of the two types do you have the fully electronic one or the manual one with sliders ?
mister munkey
Post by mister munkey » Tue Dec 14, 2010 11:06 pm
footyste123 wrote:(Front Heater Fan in Bongo is tempramental!!!!!).
Meaning what exactly?
There may well be a cheap fix for that.
The Great Pretender
Post by The Great Pretender » Wed Dec 15, 2010 1:37 am
missfixit70 wrote:Pop into Thorntons & get them to make you a chocolate fireguard, it'll be more use.
:lol: :lol: :lol: Words of wisdom. :lol: :lol: :lol:
To infinity and beyond
Bogmonster40
Post by Bogmonster40 » Wed Dec 14, 2011 8:04 pm
This happened to me yesterday - Had one of these little heaters given to me, and as it was extremely cold I thought why not give it a go. After about 30 seconds I thought what a load of garbage, the damn thing did not work.
Then I had to pop up to aberdare so needed my satnav - which is when I noticed my cigarette lighter was not working !!
Grrrrr - spent the next hour and 40 mins trying to find somewhere in the south wales valleys......
V6 2.5i Tintop Aero Petrol/LPG
perros huevos
Post by perros huevos » Wed Dec 14, 2011 10:51 pm
bolt on bits do a 12v 240w one but you would need the engine running as it will draw about 20amp they do come in handy for the old air cooled vw's that have had the heat exchangers blanked off
chris
dandywarhol
Post by dandywarhol » Wed Dec 14, 2011 11:03 pm
You'd be warmer setting fire to your farts
perros huevos
Post by perros huevos » Wed Dec 14, 2011 11:17 pm
Post by teenmal » Thu Dec 15, 2011 12:54 am
dandywarhol wrote:You'd be warmer setting fire to your farts
http://www.youtube.com/watch?v=4bB5xL577r4
