power switch for blinds
philljenk
Post by philljenk » Fri Dec 10, 2010 2:04 pm
I am trying to separate the power connector from the rear drivers side blind switch. Is there a trick to do this as it seems very reluctant to separate.
I would hate to damage it by forcing. Any help would be appreciated
thanks
Re: power switch for blinds
Post by g8dhe » Fri Dec 10, 2010 2:47 pm
Not looked at that particular switch, but yes normally there are clips that need depressing or sometimes lifting to allow release of the loom cables.
philljenk
Post by philljenk » Fri Dec 10, 2010 3:00 pm
thanks for that, thought it might be something like that, problem is finding it. Shall have another close exam of it
munroman
Post by munroman » Fri Dec 10, 2010 3:10 pm
g8dhe wrote:Not looked at that particular switch, but yes normally there are clips that need depressing or sometimes lifting to allow release of the loom cables.
I find that a short moan about the economy and the price of fuel is usually enough to do the trick! Happy to Help! :)
Post by g8dhe » Fri Dec 10, 2010 3:38 pm
Sounds like you could give Marvin some tips
philljenk
Post by philljenk » Fri Dec 10, 2010 4:31 pm
cant find any obvious kind of clip on it. There is a white bit and brown bit with the connector pins on the back of the switch, I need to reposition the switch on a side conversion. Any other thoughts would be appreciated. thanks
jaylee
Post by jaylee » Fri Dec 10, 2010 7:24 pm
From memory, they just pull apart to disconnect the switch from the loom connector....
I did a little modding over the sliding door a while back, & had the rear panel out too!
I would not be too difficult to extend the loom & reposition the blind switch...
philljenk
Post by philljenk » Sat Dec 11, 2010 12:29 pm
Success...very simple little lug on the white connector, press down and hey presto they are separated.
