Eberspacher D2 Airtronic
				flossie
 - Tribal Elder
Won a very clean looking full kit on eBay from someone in next village to me. Anyway, anyone any experience of fitting this model in a petrol model please ?
									Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
				jaybeeonline
Re: Eberspacher D2 Airtronic
If it is the D2 then it is a diesel version and not suitable for petrol power.
Some of the VW fraternity has gotten around this by installing a small diesel tank to power it by that would be a complete pain methinks.
Stick it back on eBay and get a Propex which you can run off a gas bottle and are a damn sight quieter.
J.
J.
I'll tell you this...
No eternal reward will forgive us now
For wasting the dawn.
				flossie
 - Tribal Elder
Ok I've gone back to the guy and said I'll honour purchase as my mistake but would he second chance off it to the next bidder first . So waiting to hear back ...
So now before I go off on another hair brained mission ... what am I actually trying to buy or model number(s) and what components should I be checking is included in the offer please ? Any help gratefully received
( more money than sense my Dad would say if he knew )
Liz
- B*Witched Blingo
Could you install a stationary engine fuel tank? place underneath where people fit an onboard water tank.
Like this http://www.stationaryengineparts.com/pe ... 228-0.html
You Tube Films Click Here
- Flint
 - Bongonaut
I bought a small lawnmower plastic tank off ebay which I am mounting to feed my ebaspacher as I sometimes run it on veg oil. Also this saves me cutting into the fuel system for the engine. In my book it seems a good idea to keep the two separate!!
									The saying “Getting there is half the fun” was penned with a Bongo in mind!
[color=#408040]1996 2.5 D 4x4 AFT[/color]
- haydn callow
Been there ....done that.....tooooooooDammmm NOISY
				flossie
 - Tribal Elder
I've gone back to him now and definitely not buying it so clean slate to go for the propex  thingy if that's the way to go ...
									Liz
- baronweetman
Hi pm me with the sale number please. I would haVE offered you a price for it. looking for one
									[b]la connaissance exacte du passé, en éclairant le présent, vous permettra d'agir sur l'avenir[/b]
				Stuart Dunn
Hi There,
I have one of these fitted in my bongo, and this weather it is simply the best thing since sliced bread. I time it to come on in the morning and no scraping required.
I have a seperate tank, situated where the leisure battery would sit, just a 5ltr one, this is handy if you want to run red diesel in the heater ( Not the main tank, as if you do, your asking for trouble ) because the heater isn't driving the bongo, you can use red.
They are simply brilliant, Im currently working on a fact sheet for Bongo fury which will contain pics etc as there is a place under the passenger seat which basically makes it look like it grew there. Im hoping to get the sheet written during the Christmas break, but would recommend them to anyone.
				Barrington
Here here its worth its weight in gold we could not do without ours
									Stuart Dunn wrote:Hi There,
Music is my Sanctuary!
				flossie
 - Tribal Elder
For those of you interested the item number was  160511205082
Please mention ebay login emergencyroom999 if you do make contact (thats me). Hope this is ok (Im not selling it after all!)
Good luck.
Good luck.
Liz
Hi Liz,
Good you got that sorted.
I have a propex in my V6, very good piece of kit, nice and warm and only draws 1amp. There is a potential downside though. On mine, like many others, there is only space for a 907 gas bottle. This is butane and this can freeze in colder weather. Hasn't happened yet but it is possible.
You can get petrol versions of the air heaters, they are much rarer but do exist. One thing to bear in mind though is how to tap it into the petrol system. The units have their own metered fuel pump, that wants a standard petrol feed. On the bongo it has a pressurised petrol system, with the pump inside the fuel tank. In theory then you need to install a seperte fuel take off in the petrol tank, this adds complexity.
Hope this helps.
Andy
Hope this helps.
Andy
				flossie
 - Tribal Elder
Thanks Andy
Gerry said you were really knowledgeable on this so ill pick your brains in the future. I thought in the end, petrol, diesel and LPG together in one vehicle for me was a bit too much!!
Hope someone gets it - it seemed a good one.
Liz
There are a couple of petrol air heaters going on ebay currently, likely to fetch more this time of year mind but worth keeping an eye on:
http://cgi.ebay.co.uk/eberspacher-12v-b ... 255f7ab24c
				MountainGoat
Liz, I had a propex heater fitted to my Bongo during its conversion. Specificaly told the converter that I wanted to be able to use a Calor Gas 4.5KG bottle so he made the cupboard a bit bigger than usual for me.
The only downside with the propex is that it uses up valuable under seat storage space. Get the outlet pipe fitted to one side rather than centraly if you have a rock'n'roll bed like mine to make the most of storage space.
Tony
Tony
Former SGL5 Owner Jeep Cherokee 2.5CRD  Burstner Ixeo Time it585
