Banjo filter?
Barrington
Banjo filter?
Post by Barrington » Thu Nov 18, 2010 8:11 pm
Banjo filter? sorry if this is a dumb question, where do i find the banjo filter please :oops: :oops: is there only one??? any pics please, all the best Barrington,
Music is my Sanctuary!
dave_aber
Re: Banjo filter?
Post by dave_aber » Thu Nov 18, 2010 8:14 pm
Front end of the injection pump, where the fuel pipe bolts on. Just undo the big bolt in the middle, and pull it out. It's a bit of a PITA with a side conversion - might be worth whipping the driver's seat off first. Under the Banjo there's a steel spacer, and a total of 3 copper washers to lose so go steady. No need to remove the pipe, washers or spacer, just hold them in place. Then stick a cotton bud down the middle of the whole shebang and withdraw the gauze filter.
Image...Image
Barrington
Re: Banjo filter?
Post by Barrington » Thu Nov 18, 2010 8:18 pm
pm sent Dave :D
dave_aber wrote:Front end of the injection pump, where the fuel pipe bolts on. Just undo the big bolt in the middle, and pull it out. It's a bit of a PITA with a side conversion - might be worth whipping the driver's seat off first. Under the Banjo there's a steel spacer, and a total of 3 copper washers to lose so go steady. No need to remove the pipe, washers or spacer, just hold them in place. Then stick a cotton bud down the middle of the whole shebang and withdraw the gauze filter.
Barrington
Re: Banjo filter?
Post by Barrington » Thu Nov 18, 2010 8:21 pm
Ahhhhhh im a tad lost :roll: any pics please and how to do it, sorry guys im being abit of a thickie here sorry :oops: :oops: :oops:
Re: Banjo filter?
Post by francophile1947 » Thu Nov 18, 2010 8:24 pm
Barrington wrote:Ahhhhhh im a tad lost :roll: any pics please and how to do it, sorry guys im being abit of a thickie here sorry :oops: :oops: :oops:
No pics from me, but if you search for banjo, you'll find loads of info :D
Barrington
Re: Banjo filter?
Post by Barrington » Thu Nov 18, 2010 8:25 pm
Been serching John, im still searching for a pic :( anyone!!!
Re: Banjo filter?
Post by g8dhe » Thu Nov 18, 2010 9:52 pm
brorabongo put this picture up earlier in the year;
munroman
Re: Banjo filter?
Post by munroman » Thu Nov 18, 2010 10:11 pm
PM Sent.
Barrington
Re: Banjo filter?
Post by Barrington » Fri Nov 19, 2010 2:08 pm
Many thanks Geoff & all :D
So is that the nut that houses the filter via a cotton bud please?
is there a need to bleed the fuel after or not?
many thanks again Barrington,,,
Re: Banjo filter?
Post by francophile1947 » Fri Nov 19, 2010 2:53 pm
Barrington wrote:Many thanks Geoff & all :D
Yes and no 8) :lol: :lol: Yes, a cotton bud helps to get the filter out from the bottom of the hole. No, you don't need to bleed it 8)
Barrington
Re: Banjo filter?
Post by Barrington » Sat Nov 20, 2010 6:03 pm
Cheers John :D
