Fuel system/ engine problems on our 2.5 TD Bongo!
chizzel89
Post by chizzel89 » Thu Nov 18, 2010 4:02 pm
Good afternoon everyone- I'm new here. My name is Charlie, and I've undertaken to get my parents long disused (2 years) Bongo spick and span, and sold! It's a dark green metalic 4X4, with fitted kitchen in the back with 60,000 miles. Had the head gasket replaced just before it was laid up due to corrosion and lack of use (no one has the time to use it for camping!).
The main problem with the vehicle is body corrosion. The rear arches have disappeared for the most part, along with the ends of the sills. Some minor rot to the inner sills at the front but quite localised really. I'm not too worried about this- my first car was a Ford Capri and I more or less served an apprenticship in body work repair during the 5 years I owned it and used it as my every day car!
Anyhow, the engine/ fuel system has developed an odd fault whilst it has been standing.
I went to start it at the end of last year to move it into the workshop to do the bodywork, and it refused to start. With easystart, it would splutter to life and stall as soon as you tried to ween it off the easystart.
Check and replaced the fuel filter (no nasties in the diesel filter at all).
It would now run badly on tickover, and kick out clouds of white smoke as soon as you tried to rev it, it would then stall and be difficult to re-start.
The glow plugs were almost new as well.
We then disconnected the fuel lines before the fuel filter, and poked them into a can of injector cleaner.
It started running better, and eventually regained one of the cylinders which wasnt firing.
Still wouldnt rev up though, so we held the throttle flat out. It was hunting at about 2,000 revs kicking out clouds of white smoke. After 30 seconds of this, it revved up cleanly and ran normally. No smoke, smooth as anything.
Power was good too.
However the starting problem persisted. It just wouldnt go without a whiff of easy start. If you then switched the engine off immediately, and then came to start it 6 hours or so later it would start immediately as it should. Leave it till the next morning, and it'd need the easystart again.
Anyhow, we had a bit of a family crisis, and it got left again for a couple of weeks and the old smokey, misfiring, refusing to run even vaguely normally problem is back again. It's nowhere near driveable.
I have a suspicion that something is a bit stuck in the injector pump. Or maybe the piston rings are a bit stuck...
My plan of action is as follows:
Check the fuel tank- lift the sender/ strainer out to make sure all is well in there and that the tank is not full of bacterial growth or water. However, I cannot find the sender!! I was told to look under the carper behind the drivers seat. I have looked under the first 3ft behind the drivers seat but cannot find it! Could it be somewhere else and if so where?
Check that the glow plugs are all working correctly.
Change the engine oil & filter (precaution)
Revive it with another can of injector cleaner.
Then get a friend of mine who has recovery insurance to thrash it up and down a big long hill for 10 miles or so to get it really hot so whatever may be stuck has the best chance of freeing off.
Whilst I'm takling the bodywork I'll run it up to temperature once a week.
Anyone got any ideas? I'd be much obliged to the person who can help me find the fuel tank strainer/ sender/ inspection hatch!!
Re: Fuel system/ engine problems on our 2.5 TD Bongo!
Post by g8dhe » Thu Nov 18, 2010 5:03 pm
Welcome to the forum.
This thread from Kirsty has excellent pictures http://www.igmaynard.co.uk/bongo/forum/ ... 2&p=278590
Good luck and do shout if you need more help
Post by francophile1947 » Thu Nov 18, 2010 6:25 pm
You should also give the banjo filter a good clean out 8)
Barrington
Post by Barrington » Thu Nov 18, 2010 6:52 pm
Hi John maybe a dumb question where do we find the banjo filters? and does anyone have any pics please, many thanks Barrington,
francophile1947 wrote:You should also give the banjo filter a good clean out 8)
Music is my Sanctuary!
Post by francophile1947 » Thu Nov 18, 2010 8:22 pm
Barrington wrote:Hi John maybe a dumb question where do we find the banjo filters? and does anyone have any pics please, many thanks Barrington,
Loads on here about it - try this thread http://www.igmaynard.co.uk/bongo/forum/ ... jo#p460097
dunslair
Post by dunslair » Thu Nov 18, 2010 10:31 pm
Are you running on fresh Diesel or has it been sat in the van for 2 years?
chizzel89
Post by chizzel89 » Thu Nov 18, 2010 10:50 pm
Cool will add the banjo strainer to my list!
The diesel has been topped up with a load of fresh diesel. There wasn't much in the tank during the lay-up period.
Gonna have another go at the fuel tank strainer tomorrow and rule that out... will do the banjo as well.
Thanks for the suggestions :)
chizzel89
Post by chizzel89 » Sun Nov 28, 2010 2:10 pm
Ok... some progress! Fuel pickup was blocked with what looks and smells like varnish, and the bottom of the tank had a coating of this stuff too. Cleaned it as best as I can (pick up is spotless and the white plastic pick up bund is spotless too). Been advised that its a coating on the inside of the tank dissolving and not much to worry about.
Looks like the glow plug relay is knackered... it had 12.6 volts going in to it, but wouldnt even click over and pass the current on to the glow plugs- so thats atleast half the problem.
Took the fuel pump banjo off and it was spotless in there, so I'm no longer worried about either varnishy stuff or water having partially seized the I.P
The I.P is distributing fuel to the injectors, so it is working well enough to run the engine- if the engine had glow plugs that is!
Anyone got a good glow relay they'd like to sell... or does anyone know which other less hard to find Japanese diesels were fitted with the same glow relay?
I think the Suzuki Vitara diesel has the same relay for one..
Many thanks to all!
Charlie
Post by g8dhe » Sun Nov 28, 2010 4:22 pm
At the top of the relay furthest from the connectors should be a string of numbers and letters, that's the code number you need, if it doesn't say anything until you get down to "DC12V20A" then its a standard 12 volt 20 Amp rating, after that its will probably say "NO" Normally Open followed by Imasen and their symbol proceeds the word. There are quite a few available from Ebay put the top string of numbers and letters up here and someone might have one available.
chizzel89
Post by chizzel89 » Sun Nov 28, 2010 5:37 pm
Thanks for the info.
Here's what it says on the sticker:
Glow Relay
WL 01 18 650
NGK NO.G73SV
MR82B-621 12V
56B JIDECO
Post by g8dhe » Sun Nov 28, 2010 7:05 pm
Might have guessed that they wouldn't stick with the Imasen relays forever! Looks like they have changed supplier or its been replaced in the past, having a V6 myself I use sparks rather than glows :wink:
