Help with fuel problem
BrixhamBongo
Post by BrixhamBongo » Wed Nov 03, 2010 9:21 pm
Hi all , i havent posted on here for a while , but really need some help , started my bongo on monday morning to find no power , just enough to get off the drive and 10 metres up the road . it will just about start and tickover but doesnt matter how hard i put my foot down the revs dont increase . i have had a good read of the post on here and it would make sense that it might be a fuel supply problem.
a mate who used to be a mechanic (but now works on planes) has had a look and says the hand primer on top of the fuel filter is faulty and not enough fuel is getting to the pump ,
where can i get this part from ??
i have used bongobits in plymouth before for filters and stuff , and will give them a try tomorrow
any help would be appreciated
Nick
jaylee
Re: Help with fuel problem
Post by jaylee » Wed Nov 03, 2010 9:26 pm
I ain't no techie, you sure the hose hasn't come off the turbo?
BrixhamBongo
Post by BrixhamBongo » Wed Nov 03, 2010 9:31 pm
yes checked that , thanks for the idea though :)
would that make a difference if the revs arent high enough for the turbo to kick in ?
BrixhamBongo
Post by BrixhamBongo » Wed Nov 03, 2010 9:52 pm
its the round black thing in the middle of the picture , with the 2 bolts
jaylee
Post by jaylee » Wed Nov 03, 2010 10:24 pm
Just in addition... (& this may have no bearing at all!?) RE; the hand primer. I ran out of diesel about a 1/4 mile from a garage once (about 3.5 years ago, not long after i got mine.) :oops:
Anyway, i just put a can of derv in, cranked it, & off i went for a tank up!
scanner
Post by scanner » Wed Nov 03, 2010 10:27 pm
The diaphragm under the primer can perish and develop a leak that lets air in.
Not all Bongos have that type of filter head (mine doesn't) but they are a standard item on lots of diesels so it's not a Bongo specific bit any good diesel specialist should be able to supply one.
BUT before you do that just try changing the fuel filter as your symptoms sound just like a blocked filter. It doesn't take much to block one up enough to cause problems.
Be sure to clean out the Banjo filter as well.
Post by Doone » Wed Nov 03, 2010 10:28 pm
Here are a couple of links to posts with similar symptoms to yours, they may help.
BLACK SMOKE, NO ACCELERATION
ENGINE TICKS OVER BUT WON'T REV
BrixhamBongo
Post by BrixhamBongo » Wed Nov 03, 2010 10:45 pm
thanks for your info chaps
Scanner when you say a 'diesel specialist' who do you mean , sorry to be a bit dim :lol:
Hey Allan , how are you , ive had no overheating problems since you worked your magic ! did you ever get all that oily mush cleared up after it blew everywhere ? :lol:
Post by Doone » Wed Nov 03, 2010 10:54 pm
Hey Allan , how are you , ive had no overheating problems since you worked your magic ! did you ever get all that oily mush cleared up after you blew it everywhere ?
Hello! This is Allans wife... Al's still at work. I'll let him know yours is still running magic. 8) I saw it when it came in, the muck was amazing!
Diesel specialist... I imagine this would be someone who strips down and rebuilds diesels/diesel pumps for a living? They should have access to the parts. Scanner may know someone.
Tony C
Post by Tony C » Wed Nov 03, 2010 10:59 pm
Al's still at work.
Now you're making me guilty Lorna. :oops: :oops:
I intend to live forever - so far, so good!
M 80NGO
Post by M 80NGO » Wed Nov 03, 2010 11:07 pm
You haven't misfueled it with petrol have you ?
Post by Doone » Wed Nov 03, 2010 11:08 pm
Al's still at work.
And he's in early tomorrow. So now you can feel really guilty Tony. :lol: 8)
BrixhamBongo
Post by BrixhamBongo » Wed Nov 03, 2010 11:13 pm
M 80NGO wrote:You haven't misfueled it with petrol have you ?
no filled up with a full tank about 10 days ago
scanner
Post by scanner » Thu Nov 04, 2010 1:02 am
BrixhamBongo wrote:Scanner when you say a 'diesel specialist' who do you mean , sorry to be a bit dim :lol:
In Brixham I would have though any marine engineer who does work on diesels.
Around here we used to have a Lucas/CAV depot but they seem to be few and far between these days.
BrixhamBongo
Post by BrixhamBongo » Fri Nov 05, 2010 11:21 pm
got the filter housing from bongobits in Plymouth , will fit it tommorrow , fingers crossed
