Help Auto Gearbox Problem
banty
Post by banty » Tue Nov 02, 2010 11:25 am
i have a problem with my autbox, the "hold" light is flashing.
gone through the flashing codes, it flashes 6 times slowly and then 2 times fast, is this code 62 - overrunning clutch solenoid and will it be an easy fix?
Cheers Banty.
Re: Help Auto Gearbox Problem
Post by Doone » Tue Nov 02, 2010 1:07 pm
My husband has fixed several of these, I've heard it's messy, but not difficult. There's plenty of info about the solenoid problem on the forum, a search found THESE RESULTS which should help you.
