Post
by Diplomat » Fri Oct 29, 2010 10:56 am
Did you establish that the leak was from a hose?
The water pump has already been suggested but check the joint around the top of the radiator as well.
Not too bad to cope with if the leak is high up. The worst case situation I could imagine is the metal pipe corroding where it goes up into the rear heater. Instant emptying and a s#d to do a roadside repair.
Frank
They flew, I took up naturism
