starter motor I think ? 2.5td tiin top
Posted: Sun Oct 24, 2010 3:35 pm
by jcozens
Hi I think my starter motor is on it way out you can here the motor click and it want turn try wait a few time and then it will start took it of this morning gave it a clean but still have the problem. can someone help if it is where is the best place to get on. tahanks all jamie
PS I am in the linc area.
Re: starter motor I think ? 2.5td tiin top
Posted: Sun Oct 24, 2010 4:11 pm
by wonkanoby
Posted: Sun Oct 24, 2010 4:17 pm
by mister munkey
Starting (excuse the pun) with the obvious first, check the leads to & from the battery/solenoid & starter motor are nice & tight.
Posted: Sun Oct 24, 2010 9:07 pm
by georgey
Had exactly the same problem...just a click when you turn the ignition key...went straight for the starter motor repiar kit recommended by Wonkanboby simple to fit and works a treat... good luck...
Posted: Mon Oct 25, 2010 6:19 pm
by jcozens
thanks for all your replays has anyone got a idiots guide on how to replace the parts of the starter motor including pics ?
thanks jamie
Posted: Mon Oct 25, 2010 7:14 pm
by karen
Posted: Mon Oct 25, 2010 7:42 pm
by M 80NGO
Have you tried jumpstarting it to rule out a faulty battery ?
Posted: Thu Oct 28, 2010 7:22 pm
by jcozens
yes it is the starter motor does anyone now the right part number for a 1997 r reg 2.5 td 4x4 tin top
Posted: Thu Oct 28, 2010 7:35 pm
by wonkanoby
? dont know any numbers but kit i linked to best im aware will work on a 2.5td
Posted: Thu Oct 28, 2010 7:38 pm
by mister munkey
Posted: Thu Oct 28, 2010 8:02 pm
by wonkanoby
but why would you do that when 99 percent of time the contacts are just worn
Posted: Thu Oct 28, 2010 8:06 pm
by mister munkey
Mine went wonky in the early days of ownership, needed re-winding plus new brushes.
Was quicker & cheaper to get another one.
Posted: Thu Oct 28, 2010 11:18 pm
by lars
Did mine last weekend with a kit from E-bay, under £15 delivered, with illustrated instructions. Once you see the old contacts it will be obvious if they are worn. It took me longer to get the bolts holding the starter out than it did to replace the contacts.
