starter motor I think ? 2.5td tiin top
Hi I think my starter motor is on it way out you can here the motor click and it want turn try wait a few time and then it will start took it of this morning gave it a clean but still have the problem. can someone help if it is where is the best place to get on. tahanks all jamie
PS I am in the linc area.
- mister munkey
Re: starter motor I think ? 2.5td tiin top
Starting (excuse the pun) with the obvious first, check the leads to & from the battery/solenoid & starter motor are nice & tight.
Had exactly the same problem...just a click when you turn the ignition key...went straight for the starter motor repiar kit recommended by Wonkanboby simple to fit and works a treat... good luck...
thanks for all your replays has anyone got a idiots guide on how to replace the parts of the starter motor including pics ?
thanks jamie
thanks jamie
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Have you tried jumpstarting it to rule out a faulty battery ?
yes it is the starter motor does anyone now the right part number for a 1997 r reg 2.5 td 4x4 tin top
? dont know any numbers but kit i linked to best im aware will work on a 2.5td
- mister munkey
Club Shop
http://www.igmaynard.co.uk/bongo/mercha ... #Electrics
or
http://www.igmaynard.co.uk/bongo/forum/ ... m.php?f=67 may well be a cheaper option.
or
but why would you do that when 99 percent of time the contacts are just worn
- mister munkey
Mine went wonky in the early days of ownership, needed re-winding plus new brushes.
Was quicker & cheaper to get another one.
Did mine last weekend with a kit from E-bay, under £15 delivered, with illustrated instructions. Once you see the old contacts it will be obvious if they are worn. It took me longer to get the bolts holding the starter out than it did to replace the contacts.
Hwyl a Fflag
95 silver 2WD AFT 2.5td, '96 Yamaha XJR 1200, '97 Buell S1 Lightning, '40 Indian Chief
