water leak
tay
water leak
Post by tay » Tue Oct 19, 2010 5:51 pm
hi all,after springing a leak thought i'd better have a look to see if i could find it.so ramps out engine undertray off and lo and behold there it is,the smaller hose of the two which comes out of the expansion down to the metal tree type thingy leaking like a good un. after a bit of a faff managed to get a hose which came yesterday. so last night back under van removed old hose....oh no its not the hose thats been leaking,the metal tree that the hose slips over has got a hole in it.does anyone out there know if this could be repaired,either brazed or welded.or could someone point me in the right direction so i can find a part number,looked on lush projects but cant seem to find it.in the meantime going to try some of the liquid metal stuff as a stopgap or it looks like going to the lincs bash in our little clio which could be fun four of us and camping gear as well! cheers guys tay.
i chose not to choose life ....i chose a bongo instead
Re: water leak
Post by g8dhe » Tue Oct 19, 2010 7:13 pm
It sounds like this bit;
In which case click the picture !
tay
Re: water leak
Post by tay » Tue Oct 19, 2010 8:07 pm
its similar but i believe that bit fits into the head on the engine,my leak is further forward about 600mm below the expansion tank.thanks for taking time to have a look tho.tay
Re: water leak
Post by g8dhe » Tue Oct 19, 2010 8:17 pm
Ah thats part of the A/C heating system;
http://www.lushprojects.com/bongopartsm ... 1of02.html
roughly in the middle then, it looks like its all part of the 61-2D2 pipe ?
tay
Re: water leak
Post by tay » Tue Oct 19, 2010 8:28 pm
you are the man! thats the one.the little branch to the right on part number 61-2d2 has a hole in on mine.thanks for that your'e a star.
