daveblueozzie
Post
by daveblueozzie » Mon Oct 18, 2010 11:20 pm
Ok thicko question
is there a water temp sensor position on the engine ?
The reason is im thinking of fitting one of these gauges and wondered if it will work on the bongo.
It sates on the description......
Note these are the latest technology all electronic gauges -so there is not a need for a capilliary tube connection here - the sensor simply screws into the water temp sensor position on the engine...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Lost without my Bongo.
mikexgough
Post
by mikexgough » Tue Oct 19, 2010 7:39 am
Without seeing the "paperwork" I can only assume (rightly or wrongly) that the unit comes with the relevant adapters to suit the majority of engines and it will also utilise the current Temperature gauge sensor location....
I guess and again without the "paperwork" that the unit will use the same head port for the sensor and as for the Bongo gauge it probably will render the Bongo gauge inoperable unless a connection/termination is made to the new gauge connection (if that makes sense)
Bongo is much the same as Modern motors where it employs a sender/sensor for the Temperature gauge and another sender/sensor for the ECU/Engine Fans....
daveblueozzie
Post
by daveblueozzie » Tue Oct 19, 2010 8:01 am
mikexgough wrote:Without seeing the "paperwork" I can only assume (rightly or wrongly) that the unit comes with the relevant adapters to suit the majority of engines and it will also utilise the current Temperature gauge sensor location....
Thanks for the reply and Ive had a couple of replies via pm , you all say virtually the same thing.
Basically it wont work the way i want it to.
jaylee
Post
by jaylee » Tue Oct 19, 2010 8:46 am
Dave' I think
Doone & Bulgarian
Hellen& has fitted a water temp sensor...? I believe its a case of fitting the supplied sensor with the gauge into the cooling system?? (If they haven't pm'd you already with info?)
Just to add.. I think this kind of thing was used..?
http://www.slcarsupplies.co.uk/water-te ... ter-5.html (Note; this exampled spec & type is probably wrong for a Bongo/Freda.!)
I was toying with the idea myself, & thought best leave my pipes alone!
jaylee on Tue Oct 19, 2010 8:56 am, edited 1 time in total.
You've Been Bongod
Post
by You've Been Bongod » Tue Oct 19, 2010 8:55 am
dave your hooked on bling big time mate
jaylee
Post
by jaylee » Tue Oct 19, 2010 9:06 am
Just to add. for a touch of class..
Its possible to take the backlight feed from the output on the plasma dial rheostat, & dim these dials in unison with the performance speedos..
The Great Pretender
Post
by The Great Pretender » Tue Oct 19, 2010 12:46 pm
Dave, I think they still use a bulb sensor. The easiest way to find out is to ring them, they are very helpful.
To infinity and beyond
Post
by Doone » Tue Oct 19, 2010 4:12 pm
Hello
Dave. Allan has a similar temperature gauge on his. He mentions
ON THIS LINK that he fitted the sensor into the top hose.
...You fit the sensor where you want it. I have it in the top hose. Cut the top hose, fit the adaptor with hose clips each end of the adaptor. Screw the sensor in to the adaptor. Temps read 80 around town and uphill, 70 on a run.
If you need anymore info, let me know and I'll ask him.
