Battery/ electrics help please....(keeping battery charged)
papillon
Post by papillon » Sun Oct 17, 2010 4:01 pm
hi,
Perhaps someone could help me with this (probably very simple) query.
In order to stop the battery from running flat...can I connect my sealey power pack directly to the battery terminals and also connect the power pack to mains? It seems like it would work to me ...but...not sure if I might be creating problems somewhere.
Thanks for any advice
mister munkey
Re: Battery/ electrics help please....(keeping battery charged)
Post by mister munkey » Sun Oct 17, 2010 4:13 pm
1st question - Why is it running flat? I'd be tempted to cure that first.
Or are you planning on laying it up over the winter months?, in which case just disconnect it.
papillon
Post by papillon » Sun Oct 17, 2010 4:43 pm
mister munkey wrote:1st question - Why is it running flat? I'd be tempted to cure that first.
I have the radio on etc...but do not often run the engine.
I will be using it over the winter months but it will remain 'static' for periods of time.
Post by francophile1947 » Sun Oct 17, 2010 4:46 pm
Why not just get one of these excellent little chargers http://www.lidl.co.uk/cps/rde/xchg/lidl ... _14694.htm
mister munkey
Post by mister munkey » Sun Oct 17, 2010 4:48 pm
I think I need your postcode to make that link work John . . . . :?
Post by francophile1947 » Sun Oct 17, 2010 4:54 pm
Hmm - I guess they know me :lol: but it's under the current offers on the Lidl site 8)
papillon
Post by papillon » Sun Oct 17, 2010 5:10 pm
ahh...so is the answer; I can't use the power pack in that way?
It says in the instructions that it can be plugged into the cigarette lighter socket to keep the accessories running...but tried that and it doesn't seem to work....hence....flat battery.
Post by francophile1947 » Sun Oct 17, 2010 5:13 pm
papillon wrote:ahh...so is the answer; I can't use the power pack in that way?
Your cigar lighter sockets only work with the ignition on, so your suggestion won't work, unless you rewire the sockets.
papillon
Post by papillon » Sun Oct 17, 2010 5:41 pm
yes the ignition was on (key turned to acc. and the socket was working) and the power pack via socket but it didn't keep the radio from running the battery flat.
Does anyone know if, attaching the power pack direct to the battery and simultaneously to the mains, is likely to cause a problem.
Post by g8dhe » Sun Oct 17, 2010 10:52 pm
The only way you can be reasonably certain is to turn the Ignition to OFF, then measure the current being drawn from the L/B, provided its less than a 100mA then that would be the expected and connecting the charger directly to the battery and leaving the battery on float charge it will be fine.
However its normally just as easy to disconnect the battery completely and connect the charger and then you have no worries, just make sure that the charger does go to float charge mode where it will be only pushing a few hundred milliamp's into the battery to keep it topped up.
maxi_77
Post by maxi_77 » Wed Oct 20, 2010 9:57 pm
Coupling another battery will not sop the main one going flat they will just go flat together. As the battery in one of those power packs is a mere 7 ot 12 AH it will not extend the life of your main battery very long, and as an aside flattening the stasrter battery dramatically shortens it's life. In fact flattening ang lead acid battery does not do much for it's life leisure batteries should never go below 50% to achieve their planned life.
Most of the power packs I have fiddled with have a nasty electric interlock to prevent them giving power through the sockets whilst on charge.
Your best bet would be to look at fitting a small charger direct and cutting out the power pack
White diesel Bongo
