Tyre Trouble
RFR747
Tyre Trouble
Post by RFR747 » Fri Oct 15, 2010 12:11 pm
I am new to the world of bongo and have just bought my first 4WD AFT. It currently has 195/70 R15 on the front and 215/65 R15 on the rear. I have tried to follow the advice on this site but I am struggling to get this current tyre configuration in the same brand of tyre (Goodyear GT2's included). Any advice on fitting 215s all round or should I stick with the existing set up.
Re: Tyre Trouble
Post by Muzorewa » Fri Oct 15, 2010 12:15 pm
You can get Continental Vanco Contact 2 in both sizes, 195/70R15 97T and 215/65R15 102/104T. Make sure you get the right load & speed rating as well as the physical size :wink:
Germarchip
Re: Tyre Trouble
Post by Germarchip » Fri Oct 15, 2010 12:34 pm
Don't know if this helps, but I got my tyres here
http://www.blackcircles.com
RFR747
Re: Tyre Trouble
Post by RFR747 » Sat Oct 16, 2010 2:15 pm
Thanks for the help. I got myself some Continental Vanco's this morning.
David Edwards
Re: Tyre Trouble
Post by David Edwards » Sat Oct 16, 2010 4:50 pm
Dependsd on why you want to stick to the same make,, if you have loads of money carry on,lol, I have just put another set of acceleras on mine 215 65 15 100h rated at £37.50 each, I have either used them or Nankangs and find both to be a very good tyre indeed. Shop around there are good deals about. :D Oh yeah and mine are 215's all round.
steveyd
Re: Tyre Trouble
Post by steveyd » Tue Oct 19, 2010 11:16 am
At risk of throwing a spanner in the works - you mentioned you had a 4wd, yet you have 15" wheels but with a 70 profile on the front and 65 at the back - shouldnt you be running the same size on all 4 wheels (i.e. 70 all round)? Although only a slight difference in sidewall height, its enough to change the rolling circumference which will after a few miles cause transmission windup.
There's plenty on this forum of those who've run with different sizes, then the viscous coupling overheats and gives you a bad but expensive day! Its also for this reason that lots of 4wd cars (Audi especially) specify that all 4 tyres are changed at the same time to minimise differences due to wear between old and new between axles sets.
I've got a 2wd so I can get away with this.. but 4wd is a different matter! However, if you've had these tyres on it for a while with no apparent repercussions, check your transmission for leaks or whether someone has disconnected your front diff!
cheers,
Steve
skater
Re: Tyre Trouble
Post by skater » Tue Oct 19, 2010 11:42 am
70% of 195 is near enough the same as 65% of 215
so overall circumference is the same, give or take a fraction.
If you went to full lock then did 100 circles continuously you would have problems,
not all Bongo related either :D
" it's not rocket surgery! "
Re: Tyre Trouble
Post by francophile1947 » Tue Oct 19, 2010 11:42 am
steveyd wrote:Hi,
cheers,
Steve
Don't panic Steve :lol: - those are the tyres fitted as standard for a 4WD. Front tyres are 195/70 and rears 215/65, so the rolling circumference is very close and within the official tolerances 8)
I use the same size all round as it's easier if you get a puncture - the skinny spare should be scrapped anyway, as they are ancient and unsafe :roll:
skater
Re: Tyre Trouble
Post by skater » Tue Oct 19, 2010 2:24 pm
SNAP :lol:
steveyd
Re: Tyre Trouble
Post by steveyd » Wed Oct 20, 2010 11:06 am
Cheers - didn't know that: but didn't want a fellow bongonaut to suffer, so I hope I didn't panic anyone! I'll remember that when I upgrade to a 4wd one day..
Steve
skater
Re: Tyre Trouble
Post by skater » Wed Oct 20, 2010 11:40 am
One of my local tyre fitters, part of a national chain, informed me I had
TOTALLY the wrong tyres ( experts always know best ](*,) )
Had the tracking done somewhere else.
Tyres still fine 2yrs later.
