mot fail - failed on a broken rear roll bar bracket :(
triathlondave
Post by triathlondave » Fri Oct 08, 2010 8:14 am
failed my first Mot on a broken rear roll bar bracket :(
so off the road till it's replaced
where's the best place to get a new one. As need someone to have stock and be able to post it out quick.
would people change both brackets and both bushing's at the same time? As the bushings and other bracket are good apart from the broken one. Have speed bumps all the way down my street :(
Many thanks
david.
Re: mot fail - failed on a broken rear roll bar bracket :(
Post by Muzorewa » Fri Oct 08, 2010 8:19 am
Most recommend doing both bushes and both drop-links at the same time while you've got it all in bits :wink:
321Away
Post by 321Away » Fri Oct 08, 2010 10:28 am
for fast service, i'd recommend JAS on 0845 6808 007, get 2 new bushes and brackets, only held on with 2 14mm nuts on each side, 20 minute job.
Julian
mikexgough
Post by mikexgough » Fri Oct 08, 2010 11:23 am
Muzorewa wrote:Most recommend doing both bushes and both drop-links at the same time while you've got it all in bits :wink:
=D> =D>
for the cost......I always do....... you will find that replacing one item connected to the Anti Roll Bar, weakens the other components and you WILL replace the rest in the near future.....
Image is the bracket ( around £5 each)
Image is the Bush (around £5)
Image is the drop link ( around £13)
triathlondave
Post by triathlondave » Fri Oct 08, 2010 11:56 am
Thanks for all the reply's and advice.
will order the parts today and hopefully be back on the road early next week.
will let the garage do it as have no where to work on the car safely. Plus work don't like dirty hands.
Quick question do I need to buy new nuts :shock: and bolts?
seem to remember miss fix it talking about stainless steel one's a few months ago. Plan to keep the bongo for a good few years.
David.
Post by mikeonb4c » Fri Oct 08, 2010 12:53 pm
triathlondave wrote:Thanks for all the reply's and advice.
David.
Not worth the hassle of s/s IMHO as decent (mild?) steel ones should last about the same time as droplinks when - as Mike says - its best to replace the lot in one go anyway, because the brackets fail due to fatigue not corrosion. s/s may suffer even more than mild steel in this respect.
You shouldn't need new nuts (not bolts) provided you don't have v. badd rust seizure. Best to give them a good spray with penetrating fluid/oil a decent time before trying to undo them, and use a 6-sided socket, not a 12pt star type, for best grip. And use an extension arm with the socket. But the garage will do all that I'm sure 8)
triathlondave
Post by triathlondave » Tue Oct 12, 2010 10:09 pm
The van pass it's MOT today.
£20 for the 2 brackets plus postage.
garage fitted them for free.
so happy now. thanks for all the advice.
david. :D
wishmaster
Post by wishmaster » Wed Oct 13, 2010 7:51 am
Job done =D>
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
