jasonlig
Post
by jasonlig » Tue Sep 21, 2010 12:42 pm
Very foggy this morning so for the first time i thought i would try out the fog lights on my Bongo.
The rear one worked fine using a rather bland switch (always wondered what it did) that was next to the front fog light switch.
On turning both of the switches on they lit up, but the front lights didn't(haven't checked the bulbs yet). The strange thing is that it's making a weird wurring noise, like a fan or motor has been turned on. Any ideas?
Post
by rita » Tue Sep 21, 2010 1:03 pm
jasonlig wrote:Very foggy this morning so for the first time i thought i would try out the fog lights on my Bongo.
It might be the relay chattering.
Cheers..
Post
by rita » Tue Sep 21, 2010 1:06 pm
rita wrote:jasonlig wrote:Very foggy this morning so for the first time i thought i would try out the fog lights on my Bongo.
Cheers..
PS Try turning on the head lights at the same time.
jasonlig
Post
by jasonlig » Tue Sep 21, 2010 1:08 pm
Oh thanks for the idea it could be.. its fairly loud and more wurry than clicky but worth a try.
I can hear the noise from both inside and from the bonet.
Any ideas where the relay is?
jasonlig
Post
by jasonlig » Tue Sep 21, 2010 1:09 pm
PS Try turning on the head lights at the same time.[/quote]
Oh yeah i had the front lights on while i was testing them.
wonkanoby
Post
by wonkanoby » Tue Sep 21, 2010 1:56 pm
but were they on main beam.....not just dipped
jasonlig
Post
by jasonlig » Tue Sep 21, 2010 1:58 pm
I was trying it on dipped, as i thought fog lights work best in dipped as you can see further..as the main beam always makes it worse. Or is this just me?
Post
by rita » Tue Sep 21, 2010 2:02 pm
jasonlig wrote:Oh thanks for the idea it could be.. its fairly loud and more wurry than clicky but worth a try.
If you have factory fitted lamps,the relay is normally on the N/S inner wing,the one nearest the front of the vehicle.
Cheers..
Post
by g8dhe » Tue Sep 21, 2010 2:22 pm
Are you certain that the other switch is for Front Fog Lights, neither lights or relay would make a "wurring" noise, but the quick heat start up system switch is in a similar position I think ? Now that does close various flaps and and would change the sound of the engine!!
Post
by francophile1947 » Tue Sep 21, 2010 3:34 pm
jasonlig wrote:I was trying it on dipped, as i thought fog lights work best in dipped as you can see further..as the main beam always makes it worse. Or is this just me?
No, you're right
Only driving/spot lights should come on with main beam
jaylee
Post
by jaylee » Tue Sep 21, 2010 9:03 pm
Not a (Mikeon style) scavenger fan over ride switch perchance.... ??
Post
by Northern Bongolow » Wed Sep 22, 2010 2:50 am
may sound a bit of a strange Q but does your horn work ok,maybe got a short circuit going on,as they are quite near each other,and i think the relays are.one for geoff me thinks
jasonlig
Post
by jasonlig » Wed Sep 22, 2010 12:55 pm
Thanks for all the suggestions.. no idea what the "scavenger fan" is will have to google that.
Deffinately the front fog switch, unless someone in Japan decided to make use of it for something else
Had a little poke under the bonet and it appears that noise is comming from the one of two relays next to the leisure battery. Guess i'll have to pull the offending one out to find out what part i need. Hopefully it's just a dodgy relay and not something else going wrong.
J
Post
by bigdaddycain » Wed Sep 22, 2010 1:57 pm
Hi jason, the scavenger fan is an extra fan aside from the rad fans to extract hot air, and move air around the engine compartment in the bongo.
Post
by g8dhe » Wed Sep 22, 2010 5:36 pm
Coming back to the original problem, given that it is the relay chattering, check that the earth point for the relay and lights is OK, its unlikely that the relay itself is faulty, it sounds like the extra current being drawn by the lights is then causing the relay to drop out as they use the same earth point (1);
The earth point is located here in the front
