Leisure battery - fridge issues
Huw
Post by Huw » Tue Sep 07, 2010 1:20 pm
hi there, bit of a stupid, but necessary question!
The fridge only seems to work when we have an electric hookup attached even though we have the option of Van or Car battery on our power management system. Also the PMS charge indicator for the leisure.Van battery shows zero, but when you check the battery itself, it has a charge. The PMS shows a charge for the Car battery.
any ideas?
thanks again
Huw
Re: Leisure battery - fridge issues
Post by Huw » Tue Sep 07, 2010 1:46 pm
sorry should be FRIDGE issues!
Post by g8dhe » Tue Sep 07, 2010 3:41 pm
There will be a fuse from the L/B going to the PMS unit, normally fitted close to the battery itself, probably 30Amp or so, if the battery at its terminals looks OK then the fuse would be the first place to look.
gasace
Post by gasace » Tue Sep 07, 2010 5:40 pm
Have you checked the fuse in the electric panel? the fridge uses a fuse when on 12 volts and a mcb when on 240 volts? Do your lights work from the leisure battery? Has the 12volt connection to the fridge been connected correctly?
madmile
Post by madmile » Tue Sep 07, 2010 7:06 pm
What type of fridge have you got?
Huw
Post by Huw » Fri Sep 10, 2010 7:01 pm
The lights also dont work from the leisure battery, the type of fridge is a Vitrofrigo. thanks for your help
wormey
Post by wormey » Fri Sep 10, 2010 10:09 pm
Check your earth, :shock:
Daz and debs
Jaws
Post by Jaws » Mon Sep 13, 2010 2:21 pm
Most likely the fuse on the supply from the leisure battery. Usually an in line fuse near the positive terminal of the LB. If this is the problem it does beg the question of why it blew? :-k Earthing of LB also worth a look. If not...
Which PMS are you using? Many, eg Zig CF9, are designed with caravans in mind ie no connection to car battery when on site and converters can be quite creative in how they adapt the wiring to suit!
Let us know how you fare.
Live Bongo and prosper.
Huw
Post by Huw » Wed Sep 15, 2010 3:44 pm
i'll have look, i am CRAP at electrics, and let you know. thanks for all your comments
