Full Service Inc cam belt and tensioners V6
flossie
Post by flossie » Mon Sep 06, 2010 3:07 pm
I'm quoted from Algys from 350 + VAT for this - I will check if this includes the coolant flush through and replacement. Does this sound about right ? It will be the first service on import.
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
springer
Re: Full Service Inc cam belt and tensioners
Post by springer » Mon Sep 06, 2010 3:24 pm
I just paid £180 for a full service, inc coolant flush and refill.
Also as it had just had a new head 400 miles earlier, it included a thourough check of that work.
The belt was done with the head work, so I dont know how much it was individually, but your quote sounds dear to me.
Post by g8dhe » Mon Sep 06, 2010 3:30 pm
I think it depends on the engine type diesel or V6, V6 is much more expensive as its a sod to get to apparently.
You do need to specify V6 in the title if you don' want to get odd recommendations!
Post by rita » Mon Sep 06, 2010 4:10 pm
flossie wrote:I'm quoted from Algys from 350 + VAT for this - I will check if this includes the coolant flush through and replacement. Does this sound about right ? It will be the first service on import.
Doesn'T sound too bad for a V6.
flossie
Post by flossie » Mon Sep 06, 2010 4:13 pm
Trust me to buy the expensive option ! Thanks and the point about V6 is noted :oops: :D
Liz
wormey
Post by wormey » Mon Sep 06, 2010 4:31 pm
That sounds good to me, I was quoted alot more by another dealer recently, nearly double. I will not be going there then. :evil:
Daz and debs
Re: Full Service Inc cam belt and tensioners V6
Post by haydn callow » Mon Sep 06, 2010 5:07 pm
Cam belt and tensioners alone cost about that I belive for a V6...are you sure you have it right.
Just a cam belt will probably be fine and inspect the tensioners.....worth doing cam seals though whilst in there.
And whats a Service ?? can mean anything from a oil change to a total check over.....Personally all I have done for the past 20 years is regular oil and filter and then see what a MOT throws up....not a lot as a rule...never had a problem.....
And again a coolant flush ? whats that ??? drain out whatever comes out via the radiator drain and perhaps a hose in the rad neck......that won't acheive much and will leave loads of old coolant in which may well be topped up with a incompatable coolant...(trouble down the line)
A proper flush takes 2/3 hours and involves dissconnecting the bottom hose and rear heater...then flushing...also worth running the Bongo with a chemical flush in for a good few miles the day before.....
Expect to pay £150 for a proper coolant flush/change.
It's being so cheerful that keeps me going.
Tony C
Post by Tony C » Mon Sep 06, 2010 5:19 pm
Parts alone cost £275 thats not including coolant change.
I intend to live forever - so far, so good!
Post by rita » Mon Sep 06, 2010 5:23 pm
I thought that the dealer was doing this for you as part of the deal.
Quote..............I'm paying 6700 on the road with new cambelt and 6 months tax for 2.5 v6 petrol unconverted but that's imported via Algy s - I figured I'm not in a rush as it's end of season so would rather get the better deal. It's a grade 4 of 5 with 5 being as brand new. Hope this helps oh and 53k miles ..,
A1tony
Post by A1tony » Mon Sep 06, 2010 5:30 pm
I asked at Bellhill Garage last week (they advertise on here) and they quoted around £1,200. That is because there are three tensioners on the V6, one cheap one, and two that are only available from Mazda in Japan. They are currently £287 +vat EACH.. Thats not to say they definitely need doing but until you strip it down and look for play, there is no way of telling...
I doubt Algys will be fitting those somehow.
My car came via Algy through its previous owner who only had it a month (and their garage Hallen Imports) and I have mixed views about them. Sure, they serviced it, but all the electrical conversion work has been completed with Scotchloc connectors. Cheap I grant you, but not a professional way to do the work and it does make me wonder about the rest.
Just my views..
Tony
mikexgough
Post by mikexgough » Mon Sep 06, 2010 5:34 pm
Bell Hill have a very good reputation and would fit the required parts if needed......also The George is worth a visit for Lunch....
A1tony
Post by A1tony » Mon Sep 06, 2010 5:59 pm
mikexgough wrote:Bell Hill have a very good reputation and would fit the required parts if needed......also The George is worth a visit for Lunch....
Agree, first time I have been there. Needed suspension looking at. Fitted 2 rear springs and very pleased with the result. I will probably do my own Cambelt, but if I change my mind, I might go there. I have no doubt they would only change them if needed. I suspect others might have a low initial price and then give you a 'surprise' when they tell you the expensive ones need doing by which time your car is in bits and soon to be followed by your bank balance...
cheffy34
Post by cheffy34 » Mon Sep 06, 2010 6:47 pm
I think you will find the coolant needs to be dropped to do the belt on the v6 :D
Post by bigdaddycain » Mon Sep 06, 2010 7:07 pm
haydn callow wrote:Cam belt and tensioners alone cost about that I belive for a V6...are you sure you have it right.
Tell me about it! :roll: :D
flossie
Post by flossie » Mon Sep 06, 2010 9:24 pm
Thanks all - I'll ask some more questions then - it does prices from on the price list though! Rita - Algys aren't a dealer they are an importer so I already own the vehicle in full since before it left Japan. Hallen get it through the SVA but I think I might wend my way to Plymouth to see someone with an excellent reputation - only to see his Bongo pickup of course :^o
Liz
