Auto Free Top wont go up
Dozing Passenger
Post by Dozing Passenger » Tue Aug 31, 2010 10:38 am
Although we have used "The Bongo" (its a freda really) fairly regularly mainly for transporting mattresses, beds and fridges for offspring and relatives, the aft hasn't been used since last year, until it was required over the weekend. But when it came to it nothing happened. Help, whats gone wrong, where do I look?
Engine was running, handbrake on, in "Park" pressed button, nothing!
Re: Auto Free Top wont go up
Post by rita » Tue Aug 31, 2010 11:25 am
Make sure the rubber seal is not stuck to the roof then,check fuse No 12 30 amp,in the cab by your right knee.
PS does your hand brake light come on when you apply the hand brake?
Post by g8dhe » Tue Aug 31, 2010 12:09 pm
If its not the fuse, then try the connectors on the control unit, that is situated in the rear offside pillar, you will need to remove the internal trim. There was a case recently where that was the problem.
Dozing Passenger
Post by Dozing Passenger » Tue Aug 31, 2010 2:41 pm
30 amp fuse OK, No handbrake light though! Is there a loose connection on the handbrake per chance?
Post by francophile1947 » Tue Aug 31, 2010 2:44 pm
There's a switch under the centre console, that works the handbrake light - try cleaning it up.
Dozing Passenger
Post by Dozing Passenger » Tue Aug 31, 2010 3:15 pm
Problem sorted! Switch on rear of handbrake not making good contact, spring looks a little tired I'll upgrade it I think. Many thanks all.
