Drivers side electric wing mirror
Caroline & Tony
Hi, picked up our bongo Saturday and having fun seeing how it all works. Come across our 1st problem. The drivers wing mirror doesn't adjust or fold in. I guess it could be just a fuse but if anyone has had the same problem if would be great to know how you fixed it. Thanks.
- maxheadroom
Re: Drivers side electric wing mirror
Hi and welcome
first place to look is at the wiring loom that goes from the door into the van, well know place
Welcome, I would try the above first and then start checking the voltages to anf from the mirror.
Daz and debs
Could be worse. The passenger side is further to walk round to or reach out of the window!The drivers wing mirror doesn't adjust or fold in.
They flew, I took up naturism
- mister munkey
Mine gave up a year or two back.
Turned out to be a broken wire in the loom where it runs into the door.
Easy fix & I've never looked back since!.
try seeing if its come off the mechanism,if they are knocked they disengage from the mechanism to protect themselves.i think you either gently push them all the way forward or backwards,to reengage the mechanism that moves it.
It's the door loom... Sorted this out for someone in Bristol a few months back, the speaker had gone too, along with the window... Oh the joy on the owners face as the drivers door came back to life!!!
Caroline & Tony
Thanks everyone - looking at the wiring loom at the door hinge I can see quite a few of the wires are broken. Not a lot of room in there or play on the wires to strip and reconnect them but I guess thats what I've got to do. Cheers.
This may or may not help? http://www.igmaynard.co.uk/bongo/forum/ ... iring+loom
Caroline & Tony
Thanks Jaylee - those pictures look very familiar. Think I will try my hand ar the soldering.
