Help re fitting i-alert
jeffruss
Post by jeffruss » Sun Aug 29, 2010 11:19 am
Help please!
I'm trying to connect the sensor to the rear of the cylinder head. The instructions say "find a space for running the sensor lead out from the dash to the engine". However I can see no space at all. The engine compartment seems to be sealed from the rest of the vehicle. I do see a small hole under the carpet in the driver's foot well but it's not big enough. Do I need to drill a bigger hole, or is there some obvious route for the sensor I'm not seeing?
Re: Help re fitting i-alert
Post by Bob » Sun Aug 29, 2010 12:16 pm
When I fitted a cruise I definitely didn't need to drill to get the wires from the engine compartment to the dash. I seem to recall a gromet in a suitable place, but of course it was a while ago.
If you can't find it I will go out and look.
Post by haydn callow » Sun Aug 29, 2010 12:18 pm
Lift either seat......you will see a Join/dip in the surround that the seat sits on near the front.
Run the cable to this point and across in this "dip" then put a bit of tape over it so it cannot slip out....It will come to no harm there when the seat is dowm....you may need to remove a bit of black goooo from the "dip/grove first"
If you get stuck I can take a photo
Post by g8dhe » Sun Aug 29, 2010 3:03 pm
I seem to recall that there is a route thru the footwell into the engine compartment and then back up under the dash.
A ha, just spotted that you had seen that, how big is the sensor then ?
thedogsbollox
Post by thedogsbollox » Sun Aug 29, 2010 7:37 pm
I put my TM2 cable through the grommit that the shifter cables go through. Had to stick a hole thru it like.
jeffruss
Post by jeffruss » Sun Aug 29, 2010 9:20 pm
Thanks for all the help. I passed the cable under the seat as Haydn suggested. The i-alert seems to be working now. I'll give it a good test tomorrow.
Post by Northern Bongolow » Mon Aug 30, 2010 12:33 am
may be a good time to mention that there are few/no holes in this area for a good reason,this is the fire wall.in the unlikely event that the engine catches fire,this bulkhead keeps the fire out of the cabin for a while.
