batttery light and sediment light
Posted: Tue Aug 24, 2010 9:24 pm
by tomheaney99
Yet another post lookin for help
thanks for replies so far.
Latest problem
got it back from the garage today - asked them to find a coolant leak.
turns out it is the pump. I told them i'd change it myself so when i picked it up and drove home the battery light and sediment light now stay on.... any ideas why??
I've ordered a new pump and thermostat however wont arrive for a few days. It's never ending with my bongo and i drive her so carefully. boooooo!
Re: batttery light and sediment light
Posted: Tue Aug 24, 2010 9:25 pm
by mister munkey
Shot alternator I'm afraid.
Posted: Tue Aug 24, 2010 10:17 pm
by Bongoplod
Yep,agree with Munkee,just replaced mine after the same problem,new one sorted it
Brian
Posted: Wed Aug 25, 2010 10:10 am
by haydn callow
When you do the Stat/Pump....are you o.k. with how to bleed it ...??? (not stright forward job)
Posted: Wed Aug 25, 2010 1:48 pm
by tomheaney99
ive done a bleed before (thanks to the awesome vid on youtube *buys the makes an e-pint ha, no idea wher stat is yet however it will be a few days before parts arrive.
Posted: Wed Aug 25, 2010 2:08 pm
by haydn callow
Follow the Bottom Hose up to the engine....you've found the Stat..
Posted: Wed Aug 25, 2010 2:11 pm
by munroman
Are you sure the drive belts have been tightened properly, maybe thrown back together in a fit of pique and not checked properly, hence slipping?
Posted: Wed Aug 25, 2010 3:08 pm
by tomheaney99
had a look and they hadn't put them back on... hence batt light and sed light on. problem solved ha. waiting for parts to arrive now
thanks for all the response, keeps me ticking over with the bongo otherwise by now i;d of changed motors
which i dont want to do
Posted: Wed Aug 25, 2010 5:14 pm
by copperman
If as you say they had'nt put them back on water pump would not be working so just according to distance home might be overheating problem now.Check water levels.
Colin.
Posted: Wed Aug 25, 2010 5:27 pm
by tomheaney99
ah it was only 2 min drive away. waterpump arrived today, just waiting for new thermostat
and then hopefully the coolant system is up and runnign again
Posted: Wed Aug 25, 2010 6:43 pm
by mister munkey
Good call there from Munroman, I love a happy ending
BUT
tomheaney99 wrote:had a look and they hadn't put them back on... hence batt light and sed light on.
I'd be back there with a few short sharp words at the very least.
Unexcusable behaviour.
