batttery light and sediment light
tomheaney99
Post by tomheaney99 » Tue Aug 24, 2010 9:24 pm
Yet another post lookin for help :) thanks for replies so far.
Latest problem :)
got it back from the garage today - asked them to find a coolant leak.
turns out it is the pump. I told them i'd change it myself so when i picked it up and drove home the battery light and sediment light now stay on.... any ideas why??
I've ordered a new pump and thermostat however wont arrive for a few days. It's never ending with my bongo and i drive her so carefully. boooooo!
mister munkey
Re: batttery light and sediment light
Post by mister munkey » Tue Aug 24, 2010 9:25 pm
Shot alternator I'm afraid.
Bongoplod
Post by Bongoplod » Tue Aug 24, 2010 10:17 pm
Yep,agree with Munkee,just replaced mine after the same problem,new one sorted it
Brian
Post by haydn callow » Wed Aug 25, 2010 10:10 am
When you do the Stat/Pump....are you o.k. with how to bleed it ...??? (not stright forward job)
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 1:48 pm
ive done a bleed before (thanks to the awesome vid on youtube *buys the makes an e-pint ha, no idea wher stat is yet however it will be a few days before parts arrive. :)
Post by haydn callow » Wed Aug 25, 2010 2:08 pm
Follow the Bottom Hose up to the engine....you've found the Stat..
munroman
Post by munroman » Wed Aug 25, 2010 2:11 pm
Are you sure the drive belts have been tightened properly, maybe thrown back together in a fit of pique and not checked properly, hence slipping?
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 3:08 pm
had a look and they hadn't put them back on... hence batt light and sed light on. problem solved ha. waiting for parts to arrive now :)thanks for all the response, keeps me ticking over with the bongo otherwise by now i;d of changed motors :( which i dont want to do :)
copperman
Post by copperman » Wed Aug 25, 2010 5:14 pm
If as you say they had'nt put them back on water pump would not be working so just according to distance home might be overheating problem now.Check water levels.
Colin.
tomheaney99
Post by tomheaney99 » Wed Aug 25, 2010 5:27 pm
ah it was only 2 min drive away. waterpump arrived today, just waiting for new thermostat :) and then hopefully the coolant system is up and runnign again :)
mister munkey
Post by mister munkey » Wed Aug 25, 2010 6:43 pm
Good call there from Munroman, I love a happy ending =D> =D>
BUT
tomheaney99 wrote:had a look and they hadn't put them back on... hence batt light and sed light on.
:shock:
I'd be back there with a few short sharp words at the very least.
Unexcusable behaviour. [-X [-X [-X
