how to check the oil
welsh chick
Post by welsh chick » Sat Aug 21, 2010 10:24 pm
Hey I as wondering if anyone knows how to check the oil on the bongo I think the engine is under the seat :shock:
Re: how to check the oil
Post by g8dhe » Sat Aug 21, 2010 10:31 pm
Yup your right its under the seats and between them ;-)
Good thread here and this picture of under the Passenger seat;
Its the Yellow handled bit sticking up!
roofraisers
Post by roofraisers » Sat Aug 21, 2010 10:52 pm
You are correct, the engine is indeed under the seats.
First park your Bongo on level ground & stop the engine.
You need to remove the center console tray.This is held down by 2 grey plastic wing nuts, one under the large ashtray & one inside the rear box/tray.
Then go to the passenger side seat & lift the carpet around the front lower part & you should see 2 spring over clips.Release these & then look about center of the seat in the center console area & you should see a third one to release.
The whole seat assembly should now tilt backwards & you can gain access to the engine bay. The engine oil dipstick is towards the front of the engine.
Pull it out & clean it, then insert,withdraw & see where the level is. Top up if necessary. Add the oil in
small amounts as it is easier to put it in the engine than take to it out!! DO NOT over fill, ie. take the oil level above the max level line as this may then damage your engine...... catastrophically.
Hope this makes sense,
Happy dipping 8)
Nigel.
I'm obviously a slower typer & can't use short cut links.... #-o
welsh chick
Post by welsh chick » Sat Aug 21, 2010 11:27 pm
thanks for the tips will let you knw how I get on
David Edwards
Post by David Edwards » Thu Aug 26, 2010 4:10 pm
One thing left out, oil should only be checked when engine is cold, e.g first thing in the morning after it has stood all night to get an accurate reading. Same goes for tyre pressures,lol.
Return to “Wales/Cymru”
