Cambelt Kit V6 2.5 ... recommendations please
chakota
Post by chakota » Sat Aug 21, 2010 10:40 am
Hi All,
I have been trawling through the net for a cambelt kit for my 1999 V6 2.5i petrol model. I hesitate with ebay for quality as this part is critical. In the bongo shop they only do the belt but i have been advised to changed the tensioner at same time. Has anyone got a good recommendation as to where i can purchase both items with knowledge that the parts are of good quality.
Many thanks all........Harry :wink:
Re: Cambelt Kit V6 2.5 ... recommendations please
Post by haydn callow » Sat Aug 21, 2010 10:46 am
With the V6 I understand it is o.k. to change just the belt providing there is no apparant wear on the tensioner bearings......The cost of the whole kit is loads. I know a mechanic who has done plenty and never found any wear at all.
cozmo1589
Post by cozmo1589 » Sun Aug 22, 2010 7:09 am
I had all mine done for me when i bought my new Bongo as part of garages pre delivery preparation. Apparently the belt tentionser was showing signs of wear, the garage said they changed this part too and this part alone was £250.00!!
If anyone is unsure of the service history of any Bongo engine get the cambelt changed by a specialist unless you are an expert in this field and can do it yourself. :wink: End of!
ML 270 CDi
cheffy34
Post by cheffy34 » Sun Aug 22, 2010 10:41 am
I do believe that someone had a kit from the states, but the belt is no good to many teeth as it for the 3ltr 929 the tensioners were the same tho i think, trawl thru ebay motors if you need a tensioner i have seen the same part numbers there considerably cheaper but that is ofcourse if they will post outside states :roll:
Don't quote me on any of the above tho :D
Dar
chakota
Post by chakota » Sun Aug 22, 2010 11:07 am
Hi Cozmo,
Thats rather expensive for a tensioner , trawling the net they average £75 and a wide variation on the belt , anything from £30 to £85. The mechanic i use has his own little workshop and had never seen a Bongo before but when i told him where the engine was he knew right away and said it was the same for some other Japanese makes. Like you say if you are unsure get the professionals do the job. :wink:
You've Been Bongod
Post by You've Been Bongod » Sun Aug 22, 2010 11:15 am
it would help peeps to help you if you udate your profile with the area wher you are :wink:
ian taylor does the V6 timing belt fitted for £300 ish if it doesnt need the tensioners which mine didnt other wise the kit can cost £600 alone and take around 5 - 6 hours to do
chakota
Post by chakota » Sun Aug 22, 2010 11:18 am
You've Been Bongod wrote:it would help peeps to help you if you udate your profile with the area wher you are :wink:
Hi ,
I live one mile from Santa Pod (Bedfordshire) in a little village called wymington. :) We have a Jap Show in Santa Pod on 3rd Oct. which is the third of the year , beleive it or not i have not been there yet as its free to local residents , should go to the Jap one could be interesting :wink:
