Whats this bit do ??
springer
Post by springer » Tue Aug 17, 2010 5:46 pm
Ok so my BONGO limped home today, pooor girl aint well, so I popped the bonnet, and AGHAST seems no coolant in the expansion tank, booked her in for a checkover.
But happened to spot a lever, and wondered what it is for.
Looks like on the air intake, a 2 position, manual lever, so assuming it opens and closes air intake ?? and which position should it be in, mine is facing front of BONGO.
Re: Whats this bit do ??
Post by missfixit70 » Tue Aug 17, 2010 5:49 pm
Winter/summer change over switch for the ac/heater system, Not sure which way it should be, only fitted to some models, not sure if it's just fitted to the models with the cold winter pack, e 2 batteries & the cold start valve in the exhaust as well?
Edit - just checked in the handbook (p191) & it should be forward for normal climate & back for cold climate, it says it's for the cold climate vehicle grade option, but I bet there's at least one out there that isn't :wink:
springer
Post by springer » Tue Aug 17, 2010 5:53 pm
Fountain of all knowledge comes to my rescue again, cheers.
Post by missfixit70 » Tue Aug 17, 2010 6:04 pm
Re the coolant, have you topped it up & if so by how much? or checked to see if you can see where it's leaking from?
If you aren't sure DO NOT drive it, especially if you are relying on the standard dumbed down temp gauge to tell you anything useful. You could well have an airlock which could result in expensive damage, apart from the fact you dont' know why it's lost coolant.
I'd definitely consider getting some monitoring gauges/mods/alarms sorted once you've got the problem fixed, could save you a lot of money in the long run.
But at least you know what your lever's for :wink:
Post by haydn callow » Tue Aug 17, 2010 7:22 pm
I have that lever on a 1999 V6.....Defo not got a winter pack
Post by missfixit70 » Tue Aug 17, 2010 7:27 pm
Knew there'd be at least one :wink:
Post by Northern Bongolow » Tue Aug 17, 2010 7:46 pm
pressure test the cooling system.that may show up any leaks that aint obvious
wishmaster
Post by wishmaster » Tue Aug 17, 2010 9:57 pm
haydn callow wrote:I have that lever on a 1999 V6.....Defo not got a winter pack
Mines the same as Haydn's, '99 V6 :roll: :)
Izzy
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
mister munkey
Post by mister munkey » Tue Aug 17, 2010 10:04 pm
Mine has the same lever, I've flicked between the two positions through all four seasons & it makes not one iota of difference either way.
dunslair
Post by dunslair » Tue Aug 17, 2010 10:25 pm
missfixit70 wrote:Knew there'd be at least one :wink:
I have one as well... and it isn't a winter pack / twin battery job either :lol: At least i know where to put it now :shock: (don't even think about responding to that Kirsty) :lol:
Post by missfixit70 » Tue Aug 17, 2010 10:29 pm
Spoilsport :evil: :wink: :lol:
springer
Post by springer » Wed Aug 18, 2010 9:06 am
Mine has the winter pack, twin battery, and exhaust thingy, so will set the switch and forget it.
RE the coolant - It has just had a new cylinder head, and I have not spotted a leak, so I can only assume it was filled wrongly, does it really make such a difference when filling the coolant to follow the proper procedure, cos if it does I need to tell the garage what to do.
And are the temp guages really that bad ? for it not to move one bit over temp, despite a seriously low coolant level.
Post by Doone » Wed Aug 18, 2010 12:11 pm
It's important to get the air out of the system, and your garage may know how. Opinions differ on how to do this and there are several methods they can use, including Mazdas own. Some of the methods are on a factsheet in the members area.
When ours boiled up, the temp gauge didn't move until the last second. It happened to be the last second before coolant spewed out of the header tank... We have a smart light changing temperature gauge on it now and the gauge moves when the engine works harder.
