Door electrics
snapdogs
Door electrics
Re: Door electrics
There's fuse info ON THIS LINK.
Re: Door electrics
just do a search its a comon problem.you apparently have to bang it quite hard in a certain place,but i dont know just where.
Re: Door electrics
cheers lorna
Re: Door electrics
Re: Door electrics
we will get there between us in the end
snapdogs
Re: Door electrics
You cannot open the door at all insode or out and locking button is moving ok... have tried thumping it one but to no avail... help!!!
Re: Door electrics
Did you give a REALLY hard thump or three as per the thread linked to? If that doesn't work, there's a factsheet in the members area on accessing the internals & sorting it that way, it's a reasonably common issue.
snapdogs
Re: Door electrics
the battery did have to be taken off as my hubby left the lights on van, some weeks ago.... do you think it could be linked?missfixit70 wrote:Did you give a REALLY hard thump or three as per the thread linked to? If that doesn't work, there's a factsheet in the members area on accessing the internals & sorting it that way, it's a reasonably common issue.
Re: Door electrics
That does seem to be often reported, the solution remains the same, if really heavy thumping doesn't do the trick then its a case of refer to the factsheet in the members area on how to dismantle the door to get at it.the battery did have to be taken off as my hubby left the lights on van, some weeks ago.... do you think it could be linked?
