engine wont turn off
flipflop
Post by flipflop » Sat Aug 14, 2010 5:36 pm
help !!!
my engine wont turn off have taken keys out
please need help
07899995480
Sharkojoints
Re: engine wont turn off
Post by Sharkojoints » Sat Aug 14, 2010 5:49 pm
Check the stop solenoid:
Nr 24-3002
http://www.lushprojects.com/bongopartsm ... mgno=.html
Should activate with 12v across it. You could try giving it a tap of encouragement, or unscrew and operate manually!
eta That's a drawing of the diesel pump, living under the driver's seat, in case it's not clear!
Do a forum search for "stop solenoid" and all will become clear:
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
Other methods of stopping engine:
1. Disconnect fuel pipe feed to fuel pump
2. Block air intake
I'd go for nr1 if I had to.
HTH
Post by Northern Bongolow » Sat Aug 14, 2010 6:12 pm
mechanic on scheene now guys and girls
flipflop
Post by flipflop » Sat Aug 14, 2010 6:29 pm
who doesn't know what he is doing!!!!
mikexgough
Post by mikexgough » Sat Aug 14, 2010 6:36 pm
flipflop wrote:who doesn't know what he is doing!!!!
:shock:
flipflop
Post by flipflop » Sat Aug 14, 2010 6:39 pm
The mechanic that is here! :roll:
wormey
Post by wormey » Sat Aug 14, 2010 6:43 pm
:shock:
Double :shock: :shock:
Daz and debs
integraR
Post by integraR » Sat Aug 14, 2010 6:51 pm
C02 fire extinguisher aimed at the intake should do it, if the turbos leaking oil then good luck but it prob would have gone bang by now if it was that.
wishmaster
Post by wishmaster » Sat Aug 14, 2010 6:52 pm
wormey wrote:
:shock:
#-o Who's the 'mechanic' :?:
Izzy
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
flipflop
Post by flipflop » Sat Aug 14, 2010 7:00 pm
just a guy from my insurance company, don't think they usually come across bongos
Post by missfixit70 » Sat Aug 14, 2010 7:02 pm
All he's got to do is disconnect the fuel line - or can't he find the engine #-o :lol:
flipflop
Post by flipflop » Sat Aug 14, 2010 7:08 pm
tried everything on here and more and the bugger still wont turn off!!
Sharkojoints
Post by Sharkojoints » Sat Aug 14, 2010 7:11 pm
flipflop wrote:tried everything on here and more and the bugger still wont turn off!!
Blimey - it even runs with the fuel line disconnected? I'd keep it quiet - you might be on to something big! :lol:
I reckon you might win the mpg thread if you play your cards right... :wink:
Post by missfixit70 » Sat Aug 14, 2010 7:13 pm
If it's got no fuel going to it, then it must be consuming the oil from the sump, you need to stop the air getting in, best way may be to go under the passy seat where the turbo is disconnect the plastic u bend on thr front of the turbo & block the air inlet to the intercooler/engine. If it's left to run it will go bang as it will have no lubrication, co2 extinguisher suggestion may be worth trying cos you want it stopped quick.
Either that or the mechanic ain't stopped the fuel going in?
flipflop
Post by flipflop » Sat Aug 14, 2010 7:27 pm
Thanks for all your help guys and girls, they have finally got it to stop by blocking the air intake!!
