Fitting a pedestal tabel......???
the guvnor
Post by the guvnor » Thu Aug 12, 2010 5:08 pm
Hi guys,
I am planning on fitting a pedestal table (animal skim board 8) ) behind the front seats so need to make hole in the floor to place bottom hole plate.
My questions are..........
1 has anyone else fitted one of these ?
2 what would be the best/easiest way to cut the hole ?
3 Is there anything that runs flush to the floor pan that i may cut into !!!!!?
Cheers chaps and chapesses :wink:
Re: Fitting a pedestal tabel......???
Post by haydn callow » Thu Aug 12, 2010 5:31 pm
Yep...no problem....big hole cutter...or...I used a fine jigsaw
the guvnor
Post by the guvnor » Thu Aug 12, 2010 5:33 pm
haydn callow wrote:Yep...no problem....big hole cutter...or...I used a fine jigsaw
cool. Cheers haydn. I have tried to look but its raining :roll: im guessing there is nothing that could get chopped if i use a hole cutter ?
Post by missfixit70 » Thu Aug 12, 2010 6:05 pm
You should be ok if you're careful, this may help from the waxoil thread
bongobaz wrote:
madmile
Post by madmile » Thu Aug 12, 2010 6:59 pm
It definitely requires a careful look underneath, as there is plenty you could hit with a drill if you put it in the wrong place. Have you got a flat plywood floor, or are you planning to put it onto the carpet. If the latter, I would suggest a bit of ply put under the carpet so that it beds down on a decent surface. From memory, I think the base is recessed into the floor by about 50mm.
