i alert
steady1946
i alert
Post by steady1946 » Thu Aug 12, 2010 12:10 am
Took a trip to Aldeburgh Suffolk today and got stuck in a traffic jam.My I-Alert was running at around 81-85c.I had to stop to re-fuel.I filled her up and was going to pull away when the alert started to beep and was showing 95c.Is this normal, because once I had checked to see if I had a leak :oops: ,I got on the road it went down to 81-85c again. It's a good piece of kit by the way.
Ed
Re: i alert
Post by Northern Bongolow » Thu Aug 12, 2010 1:36 am
where is it bolted to,the head or somewhere else.
mikexgough
Re: i alert
Post by mikexgough » Thu Aug 12, 2010 6:57 am
steady1946 wrote:Hi
Ed
Sounds like heatsoak to me , where the heat build up from the run plus the engine combine to raise the temperature for a short while......happens normally after a run....but.....if you had not done the short stop/restart you would never had known.....often happens in the same scenario to me.....although my Mason modded gauge reads 60% /65% dependent on the ambient and the scavenger fan runs for about 20 secends.... :wink:
Re: i alert
Post by haydn callow » Thu Aug 12, 2010 10:16 am
Perfectly normal....as has been said....heatsoak....reset it to 99C
steady1946
Re: i alert
Post by steady1946 » Thu Aug 12, 2010 4:31 pm
Thanks guys for your replys.It is bolted to the head where Haydn advised.I can stop worrying now.Haydn I will reset it to 99c.Thanks
Ed
