No indicators
dorsetdave
No indicators
Post by dorsetdave » Wed Aug 11, 2010 5:23 pm
Help required, my indicators on the bongo have stopped working, the lights externally and those on the dash are not working, but the flasher unit is clicking away, a bit faster than it should be i think, any ideas?
wormey
Re: No indicators
Post by wormey » Wed Aug 11, 2010 5:33 pm
start with checking that the battery is ok, then fuses and the relay, a new one is normally about £6 from the car shops.
It could be the indicator switch itself thats given up the ghost.
Have you got a volt meter ?
Daz and debs
Re: No indicators
Post by g8dhe » Wed Aug 11, 2010 10:16 pm
There are two possible fuses;
Image and Image
and the wiring if it helps you
If you can hear the relay clicking then it won't be the relay being the problem, most likely a fuse if ALL the lights have failed.
dorsetdave
Re: No indicators
Post by dorsetdave » Fri Aug 13, 2010 9:29 pm
many thanks for your help, it was the fuse, i think the fault happened due to a trailer i was towing for a friend had some doggy wiring. Once again thanks. Dave
