Hi guys,
Recently I've been thinking that my V6 bongo wasn't as lively at lower speeds than I recalled. I put it down to perception as the car is in top order and serviced well etc.
Anyway, I was due in at discount trucks last week for a few bits including the exhaust, and one thing on my hit list was to check the adjustment of the throttle position sensor as I have details of how this can be set up using a multimeter to measure various outputs.
The background to this was while back mine failed and I replaced it, just putting it back in the same position as the last one.
Anyway, access to the connectors on the V6 TPS is very hard, I guess the best way would be to get an old connector plug and make a testing loom so you could plug that in and get the measurements that way.
In the end we decided to set it in the middle, as it was almost impossible to get at the connectors and it was set way over one way. The range of adjustment on this is quite small, I'd say around 5mm.
Thought was put it in the middle, if worse I could put it back or forward a touch and see what was best.
Well I have to say, just putting it in the middle has made a big difference.
There is probably more to it than when it changes gear, but it does keep the engine in a better rev range, and changes up and down better more in keeping with the road speed. I felt before that just as it started picking up it would then change gear too early so the engine would drop out of it's torque band and struggle back up.
So, if you ever have this, worth checking the TPS setting. Sometimes the little things can make a noticeable difference.
I will keep an eye out for a suitable connector to make up a test loom, be interesting to see if it can be made better but I'm happy for now, gearchanges are nice and smooth as well (they were before) and MPG if anything slightly better but that really needs to be measured over time as 2 fill ups are not enough to know much other than it hasn't messed it up.
- Board index Bongo Fury Techie Stuff
- Search
- It is currently Thu May 28, 2026 9:40 pm
- All times are UTC+01:00
V6 petrol - tip if it's not as perky as expected
Jump to
- Using The Bongo Forum
- ↳ Terms & Conditions
- ↳ Guidance
- ↳ FAQs
- ↳ How to Contact Us
- Bongo Fury
- ↳ Techie Stuff
- ↳ Bongo Chat
- ↳ Breaking Bongos
- ↳ Admin & Club Matters
- ↳ Bongo Camping Equipment
- ↳ Pimp My Bongo
- ↳ Was It You?
- ↳ Off Message
- ↳ Group Buys
- ↳ Bargains!
- ↳ Small Ads
- ↳ Bongoing with Children
- ↳ Insurance
- ↳ Campsites
- ↳ Bongo Furry!
- ↳ Going Abroad
- ↳ Bongo Bash 2024
- ↳ Bongo Bash 2023
- ↳ Bongo Bash 2022
- ↳ Bongo Bash 2021
- ↳ National Bongo Day 2020
- ↳ Bongo Bash 2019
- ↳ Bongo Bash 2018
- ↳ Bongo Bash 2016
- ↳ Bongo Bash 2017
- ↳ Bongo Bash 2015
- ↳ Bongo Bash 2014
- ↳ Bongo Bash 2013
- ↳ Bongo Bash 2012
- ↳ Bulgaria 2011
- ↳ Bongo Bash 2011
- ↳ Bongo Bash 2010
- ↳ Bongo Bash 2009
- ↳ Poland 2008
- ↳ Bongo Bash 2008
- ↳ Bongo Bash 2007
- UK Groups
- ↳ Scotland
- ↳ North West
- ↳ Yorkshire & North East
- ↳ Wales/Cymru
- ↳ West Midlands
- ↳ East Midlands
- ↳ Eastern Counties
- ↳ London, Kent & Sussex
- ↳ South Wessex
- ↳ Devon & Cornwall/Kernow
- ↳ Rest of the West
- International Section
- ↳ International
- ↳ Ireland
