Will alternative clock spring fit??
Bigcol
Post by Bigcol » Mon Jul 26, 2010 9:49 am
Any techies out there have any idea whether the clock spring from a 96 Mazda 323 will fit my 96 Bongo?
The unit itself appears identical, just not sure whether the wiring will be common on both.
Re: Will alternative clock spring fit??
Post by haydn callow » Mon Jul 26, 2010 1:59 pm
Clock Spring ???
Scott
Post by Scott » Mon Jul 26, 2010 2:10 pm
haydn callow wrote:Clock Spring ???
It allows the steering wheel horn/airbag to function even tho the wheel can rotate.
Bigcol wrote:Any techies out there have any idea whether the clock spring from a 96 Mazda 323 will fit my 96 Bongo?
tbh if it looks similar it should fit, I take it yours hasn't got an airbag? If not then the only connection that runs through it is the horn wire that when grounded sounds
Scott
The user formerly known as csmcqueen ;)
スコット
Bigcol
Post by Bigcol » Mon Jul 26, 2010 7:11 pm
Cheers.
As it happens I managed to locate one from a breaker for reasonable money. Others had been quoting anything up to £80 when you can pick up clock springs for other Mazda models on Flea Bay for around the £20 mark.
Scott
Post by Scott » Mon Jul 26, 2010 10:58 pm
Bigcol wrote:Cheers.
Good find, trouble is stick the word Bongo on it and people will pay and charge the ott prices :(
スコット
