Nothing blowing from vents
Retro Bates
Post by Retro Bates » Wed Jul 21, 2010 5:17 pm
I have what could be a simple problem. When I turn the fans or sir con on I get nothing blowing. The sound are all right from the air con and engine but no wind. Help! I'm with my mechanic now.
Re: Nothing blowing from vents
Post by francophile1947 » Wed Jul 21, 2010 5:21 pm
If fan is not working, the resistor pack has probably failed - usually needs resoldering. Run a wire directly to the fan motor to check if that is still working. Resistor usually fails because fan has become stiff.
Post by g8dhe » Wed Jul 21, 2010 5:23 pm
Cold be the Fan resistor pack (if manual air system) or transistor the auto version located here;
I was actually checking the transistors with the probe.
Post by missfixit70 » Wed Jul 21, 2010 6:26 pm
FAQ here http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727 that should point you at the answers, could be the motors got wet & needs stripping & refurbing, take the scoop off the front & see if the motor spins freely, not a difficult job if so, there're factsheets on that & the fan speed resistor/control pack, do you have digital climate control or manual ac?
westonwarrior
Post by westonwarrior » Wed Jul 21, 2010 6:32 pm
sounds to me like your fans are running but no air getting in? as you say it sounds ok but not blowing
Maybe the connection by your left foot has come adrift
Post by missfixit70 » Wed Jul 21, 2010 6:44 pm
Or is the noise the rad fan running if it's switched to ac? check to see if the ac fan is actually running.
widdowson2008
Post by widdowson2008 » Wed Jul 21, 2010 6:53 pm
Retro Bates wrote:I have what could be a simple problem. When I turn the fans or sir con on I get nothing blowing. The sound are all right from the air con and engine but no wind. Help! I'm with my mechanic now.
......or could this be the problem?
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=26835
Steve
mister munkey
Post by mister munkey » Wed Jul 21, 2010 7:00 pm
If its blowing but not coming out of the vents, it could be this Old Chestnut rearing its head again.
Worth checking the linkage by your left foot.
Post by Northern Bongolow » Wed Jul 21, 2010 7:06 pm
or it could be the problem ive had today,
the motor brushes had stuck in the sliders due to water getting into the bottom of the motor.
carefully strip and service and rebuild,if your lucky like i was kirsty may ring you up while your doing the job to help. =D> =D> =D> :lol:
Post by missfixit70 » Wed Jul 21, 2010 7:15 pm
Northern Bongolow wrote:or it could be the problem ive had today,
All sorted now then? :wink:
widdowson2008
Post by widdowson2008 » Wed Jul 21, 2010 7:49 pm
mister munkey wrote:If its blowing but not coming out of the vents, it could be this
YEEEEEEEEES!!!!!!! Beat mrmonkey, and by 7 whole minutes. I've been wanting to beat you for a LOOOOOOOOOOOOOOONG time :lol: :lol:
oh bugger - Kirsty weighing in too. :( I've no chance
Steve
mister munkey
Post by mister munkey » Wed Jul 21, 2010 7:52 pm
Hats off to you Sir!
:lol:
widdowson2008
Post by widdowson2008 » Wed Jul 21, 2010 7:56 pm
mister munkey wrote:Hats off to you Sir!
:lol:
A ONE off, I assure you :lol:
Steve
Retro Bates
Post by Retro Bates » Wed Jul 21, 2010 9:06 pm
Thankyou for the kind suggestions.
He tried the resisitor, but that wasn't it, after about 10 minutes tracing where the problem could be, he came across a loose connection in the wiring. It had somehow come loose of its own accord. I'm glad it was noticed before I left.
Post by missfixit70 » Wed Jul 21, 2010 9:08 pm
Nice cheap (hopefully) simple fix then :wink:
