Air con relays
bongokar56
Air con relays
Post by bongokar56 » Tue Jul 20, 2010 2:11 pm
I am not mechanically minded at all! So be gentle with your repy.
Can anyone shed any light on where/which the air con relays are? (Or where I can access diagrams etc.)
My mechanic brother says they are not shown in the workshop manual and whilst he could try the 'trace/choose any and change method', I said some other bongo fan would probably know. [-o<
Re: Air con relays
Post by missfixit70 » Tue Jul 20, 2010 2:42 pm
Relays are well hidden down behind the drivers side headlight, 2 black cases with 8 relays in total I think, not sure which ones are which though, the FAQ may help you with faultfinding - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
What is the problem with it?
Re: Air con relays
Post by g8dhe » Tue Jul 20, 2010 5:33 pm
Wiring manuals covered here http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=36657
Choose a year then the Air con and heaters are listed in the contents under there own heading, choose between the Auto or Manual versions, front and rear.
