Rear Fog Light
Rear Fog Light
The internal gubbings on my fog light have rotted causing my light not to work so I've purchased a replacement light it arrived with no wiring instructions and no + or - markings on the casing. Does anyone have a pic they could possibly post so I can get some idea of how to wire it up please.
Many thanks
									Many thanks
Simplezzzzz
Re: Rear Fog Light
Shouldn't matter which way around, one live connection to the fused supply & switch & one to the body/earth. stick a photo of your fog internals up if you're still not sure as they aren't all the same.
						Re: Rear Fog Light
Many thanks Kirsty 3mins for a reply you're getting quicker
 no link needed so thats why
									Simplezzzzz
Re: Rear Fog Light
If its one of these...?
Put the live to the connection at the base of the bulb & the earth to the one at the side...
Thas what i got on mine!
Re: Rear Fog Light
I taake it the bulb turns & locks into the reflector? should be a connection on the back of that so you get a connection to the side of the lamp & one to the base (which is the one shown on the plastic base part) make a hole through the rubber grommet for the cable & wouldn't hurt to seal with a bit of sealant.
						Re: Rear Fog Light
liggy wrote:
You got a meter??
Re: Rear Fog Light
Yes Kirsty I took the metal connector off for the foto so the brass connection was visable. Just need to nip out and buy some more spade connectors I only have 1 left
. Yes Jaylee that is where the bottom of the bulb will sit. Many thanks I will attempt to wire it up tomorrow.
									Simplezzzzz
						Re: Rear Fog Light
While you still have day light, fit yer lamp connect the live... bring the earth wire through too & tape off.. ( You don't wan it grounding where it shouldn't, if you hit the fog button by accident!) Then crimp the female spade in the earth & fit bulb when you have the spade!
If you wasn't so far up the M4 I'd be down with one of these.. http://www.youtube.com/watch?v=yxJwP0iz ... re=related I got loads!!
