Triple/R
Post
by Triple/R » Thu Jun 24, 2010 7:36 am
Eyup all
as some of you will know i'm useless with electrics
I'm hoping someone can tell me how to wire this socket up please as theres only one terminal & usually theres a live & earth one~also what amp fuse for inline fuse should i use.
Thanks Ray.
Regards Ray & Christine
jaybeeonline
Post
by jaybeeonline » Thu Jun 24, 2010 7:49 am
The bullet connection in the centre is the live and the one on the side is the earth.
J.
I'll tell you this...
No eternal reward will forgive us now
For wasting the dawn.
Triple/R
Post
by Triple/R » Thu Jun 24, 2010 7:57 am
Brilliant J~any idea what fuse rating.
bobngo
Post
by bobngo » Thu Jun 24, 2010 8:46 am
given its 12 volts type, divide the wattage rateing by 12 , then double it.
so ,say its 36 watts (notice how i picked an easy number ) divided by 12 equals 3, times 2 equals 6amps
dave_aber
Post
by dave_aber » Thu Jun 24, 2010 9:11 am
And with that calculation in mind, remember that the fuse is there to protect the circuit, so the wiring must be 6 amp or more. No point in having 4 amp wire protected by a 6 amp fuse....
That's the same socket I have used in my conversion. Works a treat.
Also - whilst you are planning on using a coolbox and can work out the wire/fuse ratings based on that bear in mind that the socket is pretty universal so could be used for anything else that fits.
Those that understand
binary, and those that don't.
jaylee
Post
by jaylee » Thu Jun 24, 2010 9:27 am
Triple/R wrote:Eyup all
Thanks Ray.
Looks like a nice solid tidy unit Ray..!
Where did you get it from??
dave_aber
Post
by dave_aber » Thu Jun 24, 2010 9:56 am
mikexgough
Post
by mikexgough » Thu Jun 24, 2010 11:34 am
I got rid of those on my conversion and went for CBE sockets instead.....
with a
frame...... jobs a good un and 10 amps..
Triple/R
Post
by Triple/R » Thu Jun 24, 2010 12:26 pm
Thanks for all your replies~i knew you would'nt let me down
Jaylee, it's a caravan one that's fitted in an ouside flap along with a 240volt socket.
