Radiator advice
Sluggy
Radiator advice
Post by Sluggy » Mon Jun 21, 2010 8:57 am
Hi folks,
I need to get a new radiator, but I'm a little stumped by the selection available, ranging 99pound upto 250...
Now the 250 ones are obviously Mazda originals and the recommended part, but what is OE specification/quality?
There is this one available on fleabay for 149 which says it is OEm approved quality???? - with a lifetime guarantee??!! - here
or this one from JAS which is apparently the "recommended unit"
or here's the 99er... should I avoid at all costs??
Does anyone have good/bad experiences of the cheap ones or can anyone recommend one? (the original is out of the question - just tooo expensive!)
:D
scanner
Re: Radiator advice
Post by scanner » Mon Jun 21, 2010 9:18 am
I'd feel better about that company if they'd checked their spelling.
ALTINATOR
BREAK HOSE/PADS/DISCS
CYLINDER HEAD/GASKITS
FILTERATION
WARRENTY
Cheepest on Ebay
What else are they slapdash about?
helen&tony
Re: Radiator advice
Post by helen&tony » Mon Jun 21, 2010 9:49 am
Hi Scanner...
Americans???...they're illegitimate :lol: :lol: :lol: :lol: :lol: :lol: coz they carnt reed an rite proparlee
mikexgough
Re: Radiator advice
Post by mikexgough » Mon Jun 21, 2010 10:09 am
I can recommend the JAS one..... it's O.E quality and build without the O.E price tag...... it's made by the suppliers to Mazda without the Mazda packaging..... :wink:
Sluggy
Re: Radiator advice
Post by Sluggy » Mon Jun 21, 2010 10:46 am
mikexgough wrote:I can recommend the JAS one..... it's O.E quality and build without the O.E price tag...... it's made by the suppliers to Mazda without the Mazda packaging..... :wink:
Aha! thats the kind of nugget I'm searching for :wink:
David Edwards
Re: Radiator advice
Post by David Edwards » Mon Jun 21, 2010 10:28 pm
If you look on the thread below re radiator I have put a link to a company I got mine from, superb at £111.00 delivered with a two year warranty.
Sluggy
Re: Radiator advice
Post by Sluggy » Thu Jun 24, 2010 9:17 am
Ok, so had the JAS unit fitted yesterday by my mechanic I've been using for a few years, and also the large top engine hose replaced (the one under the drivers seat) which was starting to swell, cost me 120pound (whats wrong with this bloody pound sign!?) excluding the rad and hose which I sourced myself.
Need to keep checking the level but fingers crossed... [-o< I've got a working Freda again... :D
scanner
Re: Radiator advice
Post by scanner » Thu Jun 24, 2010 10:18 am
Nothing..££££££££
Sluggy
Re: Radiator advice
Post by Sluggy » Thu Jun 24, 2010 6:23 pm
mine just comes up with ####### (shift 3) and the # button comes up with \ and the \ button comes up with \. :lol:
scanner
Re: Radiator advice
Post by scanner » Thu Jun 24, 2010 7:08 pm
Sluggy wrote:mine just comes up with ####### (shift 3) and the # button comes up with \ and the \ button comes up with \. :lol:
Somebody's messed with your keyboard settings.
Try seeing if it's set as US instead of UK
mikexgough
Re: Radiator advice
Post by mikexgough » Thu Jun 24, 2010 7:11 pm
Glad your sorted with the JAS supplied unit..... :wink:
Re: Radiator advice
Post by missfixit70 » Thu Jun 24, 2010 7:38 pm
Make sure the oil cooler connections are screwed tightly into the borrom of the rad, my recently fitted JAS rad seems to have developed an ATF leak on the passy side joint, have to get the intercooler scoop off tomorrow to have a proper look.
Re: Radiator advice
Post by Northern Bongolow » Fri Jun 25, 2010 3:53 am
the one i fitted for kev was the same kirsty,sorry should have said at the time #-o
mikexgough
Re: Radiator advice
Post by mikexgough » Fri Jun 25, 2010 7:02 am
missfixit70 wrote:Make sure the oil cooler connections are screwed tightly into the borrom of the rad, my recently fitted JAS rad seems to have developed an ATF leak on the passy side joint, have to get the intercooler scoop off tomorrow to have a proper look.
Mine were loose when I got mine and as I noticed I nipped them both up prior to fitting..... :wink:
Sluggy
Re: Radiator advice
Post by Sluggy » Fri Jun 25, 2010 1:35 pm
can I see these connections from under the front bumper?
