Clunk in Suspension
Davo
Clunk in Suspension
Post by Davo » Fri Jun 18, 2010 3:47 pm
Hi, my Bongo has developed a clunking noise in what I think is one of the front suspension springs or shock absorbers.
The noise only happens when I change direction and then apply the brakes. ie I stop, select reverse, and as I apply the brakes there is a clunk.
Similarly, when I then move forward and apply the brakes, it clunks again. It doesn't happen again, even over bumps or when braking, until I use reverse.
The mechanic says it is the spring or shock absorber settling back into position and that it is nothing to worry about...
Anyone else had this?
gmaczbongo
Re: Clunk in Suspension
Post by gmaczbongo » Fri Jun 18, 2010 4:07 pm
Could it be play in the brake caliper mounts.
Could also be loose.
Davo
Post by Davo » Fri Jun 18, 2010 4:18 pm
Good thought! Thanks
Post by Doone » Fri Jun 18, 2010 9:11 pm
Ours both cluncked and clicked before the the brake 'wear markers' were fixed.
