Buttons on the gear stick??
bongobridge
Post by bongobridge » Fri Jun 18, 2010 2:45 pm
What are the two different buttons on the gear stick for? I believe one of them is a hold button - when would I use this and do I have to 'hold' the button down? Can these be switched on/off when the engine isnt turned on - just thinking about the kids messing around pressing things they shouldnt!
Nick & Jen
[color=#FF8000]life's a beach, then you fry[/color]
bongomadness
Re: Buttons on the gear stick??
Post by bongomadness » Fri Jun 18, 2010 3:06 pm
The hold button is basically a manual overide for when you are going up places like snowdon or ben nevis or use it in the winter when it is icey or snowy.
Jayne
timjonz
Post by timjonz » Fri Jun 18, 2010 3:07 pm
The HOLD button keeps it in a low gear, if pressed while in D then it wont go above 3rd. Use this for slowing down/controlling the speed especially useful going down hill.
I don't think it can be activated while the ignition is off, HOLD should be displayed on the dashboard when it is active, press again to deactivate.
My stick only has the hold button & the big one for putting into reverse so I can't help any more than that.
Tim
bongobridge
Post by bongobridge » Fri Jun 18, 2010 3:17 pm
bongobridge wrote:What are the two different buttons on the gear stick for?
I meant to put, there are 2 buttons on the gear stick, what is the smaller one ie, the hold button.
Thanks guys for your replies, now I know what it does, and if it lights up on the dash then at least I will know when it is on and if the kids have been messing - although the window wipers and hazard lights on are usually a dead give away!!
Nick & Jen
Alison01326
Post by Alison01326 » Tue Jun 22, 2010 12:08 am
Watch your window switches if you've got kids who mess around :roll:
Not only did mine keep pressing the lock switch for the windows, but he eventually broke the "missile launcher buttons" and they are extremely expensive to replace.
Of all the threats I make, I think the only one he still believes is that I will cut his fingers off if I have to replace the window switches ever again.
Alison
.co.uk
Post by .co.uk » Tue Jun 22, 2010 10:06 am
I thought you were suppose to press the big button every time you move the gear stick, for example, from D to P. Is it okay to move it without pressing the big button?
[b]G'day from The People's Republic of the Bongo![/b]
www.thomasgorman.co.uk
Post by Muzorewa » Tue Jun 22, 2010 10:07 am
You only need to press the big button to move it out of P and to move from N to R I think. Oh, and into L as well :wink:
dp bradford
Post by dp bradford » Tue Jun 22, 2010 6:19 pm
bongobridge wrote:.....I believe one of them is a hold button - when would I use this and do I have to 'hold' the button down?
The full story is:
In D the van has the full range of gears, with the Hold button pressed it will use only 2 and 3 (good in snowy conditions)
In S the van will use only 1, 2 and 3 - pressing Hold forces it to use only 1 and 2
In L the van will use only 1 and 2 - pressing Hold forces it to stay in 1
Good for forcing a lower gear on steep descents
The Hold button has a 'toggle' function; press once to activate, and again to deactivate - no need to hold it down.
Dave :D
jaylee
Post by jaylee » Tue Jun 22, 2010 8:01 pm
While were on the subject.,.. Do you think Scott's Cylon will wipe out the whole human race??/
dp bradford
Post by dp bradford » Tue Jun 22, 2010 8:12 pm
jaylee wrote:While were on the subject.,.. Do you think Scott's Cylon will wipe out the whole human race??
WTF???? I think it puts us all at risk, yes :shock:
Dave :roll:
