sediment light lit up
FREDA MIND
Post by FREDA MIND » Tue Jun 08, 2010 7:32 am
hi guys,,,,
it was my charge light friday,,,, now my sediment light has come on.
:roll: :shock: =D>
im guessing this has something to do with diff oil????
can anyone enlighten me
cheers
ricky
have yourself a midlife chrisis,,,,go buy a bongo!
kawasaki kid
Re: sediment light lit up
Post by kawasaki kid » Tue Jun 08, 2010 8:16 am
When the altenator is failing these lights come on - the sediment light is part of your fuel filter and nothing to do with your diff oil. May be worth getting your altenator checked out as you will end up with a flat battery if it`s failing.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Post by haydn callow » Tue Jun 08, 2010 9:21 am
Underneath your fuel filter is a sediment trap which does what it says (catches muck/water) when it gets full the sediment light will come on.
Having said that, as said above ...it also when the alternator is failing, it is a warning of this happening and both the charge & sediment warning lights will start coming on.....
FREDA MIND
Post by FREDA MIND » Tue Jun 08, 2010 10:19 am
thanks guys, ive got a new alternator on order,
should be here today.
this site is the dogs nadgers!!! 8) 8) :lol:
ricky :D
