Drove off with coolant lid off !!
droodle
Post by droodle » Sat Jun 05, 2010 12:29 pm
Just been a numpty and topped up my coolant forgot to put the cap back on then drove 2 miles down the road before i saw water bubbling everywhere .. thankfully the cap was still there :)
I've put about 2 litres of water in but now the gauge is moving from 11 - 1pm which its never done before on the 3 mile drive back.
Airlock ?
Or something else ?
westonwarrior
Re: Drove off with coolant lid off !!
Post by westonwarrior » Sat Jun 05, 2010 12:38 pm
make sure you bleed the system properly
wishmaster
Post by wishmaster » Sat Jun 05, 2010 12:41 pm
Yip needs a bleed
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
droodle
Post by droodle » Sat Jun 05, 2010 12:49 pm
Wonderful .. i have no idea how to do that .. anyone in brighton with the know how ??
or how much should a garage charge ?
ta.
Post by francophile1947 » Sat Jun 05, 2010 1:15 pm
Fact Sheet in the Member's Area 8)
droodle
Post by droodle » Sat Jun 05, 2010 1:21 pm
Thanks but i just read that prior - it may as well be in arabic .. if garages get it wrong as i've read here frequently, i have absolutely no cofidence that i would be able to do it correctly.
bongomadness
Post by bongomadness » Sat Jun 05, 2010 1:47 pm
I know where you are coming from there. The cooling system on the bongo is a spaghetti of pipes!!
Post by Northern Bongolow » Sat Jun 05, 2010 3:20 pm
pm sent
Alison01326
Post by Alison01326 » Sun Jun 06, 2010 12:17 am
droodle wrote:Thanks but i just read that prior - it may as well be in arabic .. if garages get it wrong as i've read here frequently, i have absolutely no cofidence that i would be able to do it correctly.
Most of the garages who get it wrong are not following the fact sheet as they think they know better [-X If you can't get to a garage experienced with Bongos, make sure that the person you use follows that fact sheet to the letter.
Alison
Post by haydn callow » Sun Jun 06, 2010 9:48 am
You would be amazed (or not) at the number of garages who get it wrong with Bongos.
Just last week I had a lady on the phone who was having overheating problems and had had her garage replace a hose.
I phoned the garage and was tolld they had bleed the system and had fitted many cylinder heads and gaskets. I asked them if they used the bleed pipe under the passenger seat...Silence from the other end.....Says it all.
droodle
Post by droodle » Mon Jun 07, 2010 11:17 am
Sorted it at my local bongo friendly garage .. who bled it for me and did a pressure test at the same time for £15 .. needle back sitting at 11 :)
countycars in brigton/portslade recommended .. seemed a friendly bunch.
Special thanks to the two forumites who PM'd me offering to talk me through it on the phone and the other coming over at a later date - sorry couldn't wait .. only car now.
Great forum !
ronhud
Post by ronhud » Mon Jun 07, 2010 2:09 pm
Fit a low level coolant alarm, I forgot the cap and it alarmed as soon as the level started to drop.
Ron
