Fuel pump seals
- Bongonaut
Fuel pump seals
HELP !!!!
After 6 years my Bongo has let me down. Does this mean that it is unreliable and I should get something else?
Only joking.
Failed MOT on fuel leak and broken bracket on anti roll bar. Got the parts from the shop. I am trying to put the seal in the back of the pump by the blanking plate and it will not go. Both the seals I received in separate packs were a greenish colour and the same size. Is this correct. Main reason for asking is that the fact sheet shows a greenish and a black seal which looks a slightly different size.
Yours frustratedly
Simon
Only joking.
Yours frustratedly
Simon
Re: Fuel pump seals
Hi Simon,Simple Simon wrote:HELP !!!!
Only joking.
Yours frustratedly
Simon
The black seal is the old one,the green on is the modified (new)one.You might need a wee bit of grease or similar to hold it in place.
- Bongonaut
Re: Fuel pump seals
Many thanks
I'll have another go at Gynaecology!!!
Simon big hands!!!!
Simon big hands!!!!
- Bongonaut
Re: Fuel pump seals
Any one need a baby sucessfully delivered!!!!
Amazing how a tea break can lead to a positive turn on things!
Now for the roll bar bracket and bush......look out Bongo, here I come........ an I ain't takin no prisoners!!!!!
Re: Fuel pump seals
simon have you any photos of the job bieng done,if not can you do it again with photos.
i have read the factsheet in the members area,and to be honest its a bit vague,shows the bits but not how where etc,looking really for something more than,its a fiddly job,heres the seals.
Re: Fuel pump seals
Northern Bongolow wrote:simon have you any photos of the job bieng done,if not can you do it again with photos.
Hi,does this help,
http://www.igmaynard.co.uk/bongo/forum/ ... ls#p129685
Re: Fuel pump seals
thankyou very much rita,thats the sort of info you need,and from a trusted spanner man to,it dont get much better thanks,
sorry dont do the computer thing very well,bit better with the spanner stuff.
- brorabongo
Re: Fuel pump seals
Just to say that Ian advised me today that the club shop is out of seals until early July, on the advice previously given by Dandywarhol I contacted Lawson Diesel, http://www.lawsondiesel.co.uk/, and straight away the very helpful guy knew what I was needing, they are £5.93 including postage.
Looking forward to skinned knuckles already!
Re: Fuel pump seals
To give more room between the pump and the engine you can rotate the pump toward you after slacking off the the two 12m/m nuts that secure it. Probably best to undo the battery.
Re: Fuel pump seals
Your original advice (on another thread) included a reminder to use tippex to make the position accurately before moving anything. Was that to ensure the pump timing was reset accurately when job finished, as I gather that is absolutely critical to proper running. Most important that advice be heeded if so.Tripewriter wrote:To give more room between the pump and the engine you can rotate the pump toward you after slacking off the the two 12m/m nuts that secure it. Probably best to undo the battery.
Re: Fuel pump seals
Yes best to return pump to original position, however if running on VO or parafin, meths, ginger beer etc another position may actually be better. Movement is very small in terms of degrees and my guess is that bongos will run wherever the pump is but will not run well across the whole range of revs. Rather like the distributor when petrol cars had contact points.(god I'm old).
- mikexgough
Re: Fuel pump seals
I like the idea of the "tippex" marking....useful as I am old school too.....used to do that trick with distributors.....however....should be checked with the relevant tool to assure absolute accuracy......
I had to have a new diesel pump at the end of last year and that was "dialed" in to spot on by Bell Hill Garage, who fitted it.... and to add to the mix....I run 20-30% veg in mine.... another thing to add.....since the pump was replaced......6 mpg improvement...
so I guess.....use the tippex BUT get it checked for absolute accuracy at a Bongo or Diesel specialist...
- dandywarhol
Re: Fuel pump seals
Diesel pumps - even old school pumps like Bongo (and Hiace
) need to be timed to the nearest 0.1mm with a DTI gauge
Re: Fuel pump seals
I have just done mine with a combination of the 'old' and 'new' loosen off pump method, what I did before loosening the pump was to gently hammer an electrical screwdriver at an angle where the pump joins the engine, I made a good mark, (not a scratch),on the pump and engine.
When I was ready to tighten the pump, I turned it until the screwdriver blade fitted perfectly into both marks, this ensures the pump goes back exactly to where it was, then held the blade in the marks until I had tightened the pump, simples!
