spares kit needed light bulbs hoses etc.
gasace
Post by gasace » Tue Jun 01, 2010 12:44 pm
Hi everyone I am putting together an emergency spares kit, I have several hoses and have ordered fan and air-con belts. Can anyone help with bulb types? and if you can think of anything else, that is small enough to keep on board and may take time to get, I would be grateful. I'm thinking that unlike a car, if I am away with my bongo (camper) if it can't be fixed I loose my home as well as my car until it's back on the road.
Gasace
Re: spares kit needed light bulbs hoses etc.
Post by Northern Bongolow » Tue Jun 01, 2010 12:48 pm
compatible coolant,maybe
Post by Muzorewa » Tue Jun 01, 2010 12:53 pm
Bulbs for ours (1998) :
Headlights H4 (Halfords 472)
Front sidelights W5W (Halfords 501)
Front indicators PY21W (Halfords 581)
Rear indicators PY21W (Halfords 581)
Stop/Tail P21/5W (Halfords 380)
Reversing light P21W (Halfords 382)
Older ones have clear indicator bulbs so presumably the same as the reversing light
Post by missfixit70 » Tue Jun 01, 2010 12:57 pm
I carry a little case with spare ATF, engine oil, brake fluid & diff oil under the passy seat, jump leads, spare fuel filter, bulbs, belts, loads of mini fuses & the bigger fuses under the bonnet as well as fuses for the split charge, hose repair tape, some jubilee clips, cable ties, gaffer tape, insulation tape, tool kit, rags, spare coolant, windscreen washer fluid, tyre pump.
Make sure you check your spare tyre & if its the wheelbarrow tyre, get it changed for a proper full size spare, then at least you can carry on your journey. Full pack of factsheets printed out is a good idea, or if you're taking a laptop, download them or get the little preloaded memory stick from the club shop, At the very least have the bleeding instructions printed out.
Don't forget you yellow vests & warning triangles.
jaylee
Post by jaylee » Tue Jun 01, 2010 1:11 pm
missfixit70 wrote:I carry a little case with spare ATF, engine oil, brake fluid & diff oil under the passy seat, jump leads, spare fuel filter, loads of mini fuses & the bigger fuses under the bonnet as well as fuses for the split charge, hose repair tape, some jubilee clips, cable ties, gaffer tape, insulation tape, tool kit, rags, spare coolant, windscreen washer fluid, tyre pump.
Make sure you check your spare tyre & if its the wheelbarroe tyre, get it changed for a proper full size spare, then at least you can carry on your journey. Full pack of factsheets printed out is a good idea, or if you're taking a laptop, download them or get the little preloaded memory stick from the club shop, At the very least have the bleeding instructions printed out.
:lol: You ain't kidding Kirsty, its like someone removed the engine & dumped the contents of Auto parts & Lidl in there! :wink: :lol:
Post by missfixit70 » Tue Jun 01, 2010 1:23 pm
I like to be prepared & don't like wasting space :oops: :P :lol:
Oooh & a towrope, make sure you've got your jack , long bar for removing the spare tyre, ratchet & THE RIGHT SIZE wheel nut spanner, I was driving around for a few months with one in the tool bag that when I checked, didn't fit the wheelnuts, I always carry one of those extending one that Lidl do aver few months for amout £3, absolutley brill, makes a good "nightstick" too if you're wildcamping or using Aires :wink:
Alison01326
Post by Alison01326 » Tue Jun 01, 2010 1:28 pm
Sounds like a good bet would be to just pay Kirsty to take you on holiday in her Bongo :wink:
You've then got all the spares, and someone who actually knows what to do with them (which I certainly wouldn't :oops: )
Alison
bongobaz
Post by bongobaz » Tue Jun 01, 2010 1:32 pm
A little case? Sounds like trailer is required.
think i'll stay off the forum fo a bit i'mImage
Always be ready for a Top Up!
gasace
Post by gasace » Tue Jun 01, 2010 4:44 pm
Thanks everyone, I will get the stuff before the next trip, hopefully tomorrow weather permitting regards
gasace
You've Been Bongod
Post by You've Been Bongod » Tue Jun 01, 2010 7:48 pm
dont forget a warning triangle
a florecent jacket
a full size spare wheel to replace the skinny one
Post by Muzorewa » Tue Jun 01, 2010 7:52 pm
....and a map :wink:
