Wiring for rear spoiler
dext924
Post by dext924 » Sun May 30, 2010 7:14 pm
Hi again,
Well, with some scratchin of head, bit a time and alot of swearing, the rear spoiler has founds its way out of the shed on to the back of the Bongo. Possibly not the neatest job, but it is there none the less.However, I am a bit confused as to the wiring.
I have fed the wires through so i can now get them from the rubber gromet when the door is open, but I was wondering if anybody could tell me which is which wire? I have a black and green one from the spoiler, and I take it they need to go in to the little group of wires in the rear door. How do you find out which you need?
I have one of those thingys that I found the live wire for attaching my sensors and alarms, would that work when the brake pedal is pressed?
Any help appreciated
Thanks in advance
dreamwarrioruk
Re: Wiring for rear spoiler
Post by dreamwarrioruk » Sun May 30, 2010 9:18 pm
i did a factsheet about 4 yrs ago with the colours for a 95 sgl5 aft which might be of some use in the members section.
mike, jo and emma
Post by g8dhe » Sun May 30, 2010 9:22 pm
The connectors are F3-02 (Black wire - ground) and F3-05 (Green / Yellow stripe +12volts) in the digram below;
which are located here;
dext924
Post by dext924 » Sun May 30, 2010 9:37 pm
thanks, will take a look at that this week. Makes a bit of sense, but as you might be able to tell, I am a little technical challenged when it comes to stuff like this!! :lol:
