Turbo late in "kicking in"
muirmicro
What sort of Revs would I expect the turbo to kick in on my 2.5 Bongo TD 2WD
Seems mine comes in at over 3500 rpm !
Re: Turbo late in "kicking in"
just under 2000rpm
muirmicro
Thanks for speedy response
Any Ideas as to why mine is later in coming in or what can be done ?
is yours an auto? if yes , how do you know its coming in late? it may be coming in but it may be weak/worn.
is this the only symptom regarding performance,does it change gear when it should.
quick check around the air/vacuum pipes to the turbo may help,check the air inlet system from where it comes in next to the starter battery all the way through the air filter/housing,round the back of the engine,forward to the turbo then forward to the aftercooler and back to the inlet manifold,all these pipe conections should be airtight
Like Ady, i hear mine spooling up around the 1800RPM mark depending on engine load at the time...
muirmicro
I'm new to the bongo but my car and all my previous cars have beeen TD's and have kicked in at about 1800/2000 rpm. The bongo is sluggish, it accelerates slowly to 3200 rpm in 2nd gear then takes of, the gearbox then changes up through third to fourth quite quickly then it dies, again if you let it accelerate slowly in top it will then takes off once engine has hit 3200
I have just had it serviced and the transmisson fluid changed and gearbox filter cleaned, garage say that it was a bit dark in colour but nothing that they would say should concern me. I also got them too check the intercooler to turbo pipes but will check other myself at weekend
Check the fuel filters been changed & not leaking & check the banjo strainer on top of the fuel pump.
- dandywarhol
Is it a post '99 model with the electronic fuel pump? There's been recent posts like this on these models
muirmicro
Thanks for all the help
My Bongo is a 95 2.5TD 2WD Auto
muirmicro wrote:Hi
Hi muirmicro,
What speed are you doing at 3200 RPM and in second gear??
- dandywarhol
Check this hose hasn't disconnected
Dandy was of course checking that his coolant top hose wasn't about to suffer a ruptured aneurism. Crikey, it looks like something out of a pathology textbookdandywarhol wrote:Check this hose hasn't disconnected
- dandywarhol
Coolant hose had just swallowed a small bongo and was digesting it over a period of weeks
Spot on - I knew that pic reminded me of something but just couldn't place itdandywarhol wrote:Coolant hose had just swallowed a small bongo and was digesting it over a period of weeks
