coolant - how much, what mixture
robbie c
Post by robbie c » Sun May 16, 2010 8:34 pm
Hi, just a quickie.
how much coolant goes in the 2.5 diesel and what's the antifreeze mixture ratio. Can't seem to find the info in the book.
cheers
Rob
Re: coolant - how much, what mixture
Post by Northern Bongolow » Sun May 16, 2010 8:42 pm
holds 13/14litres i think,but doing a coolant change you will prob only drain out 9/10 litres out
i do 50/50 mix so you will need just over 1x5litre antifreeze and keep the rest for compatible top up mixing.
