I have an annoying buzz coming from it and need to check it out. Already whacked it just in case that would help but it seems more investigation is required
I think Cosmic Bus may be referring to small round speakers fitted to some Bongos behind the cab roof where the rear vents are.Scott & Sophie wrote:Good bit of help with getting the door panels off in the central locking factsheet, in the members section. Once they're off you can do what you want to the speakers!
