is this correct egr blank places??
chipvan
Post by chipvan » Fri Apr 16, 2010 6:27 pm
am i on the right tracks??
also is it just a thin bit of tin needed got some gas fire colsure tin ??
cheers guys
http://s723.photobucket.com/albums/ww23 ... egi005.jpg
http://s723.photobucket.com/albums/ww23 ... egi004.jpg
Re: is this correct egr blank places??
Post by francophile1947 » Fri Apr 16, 2010 6:34 pm
I just used a 2p coin between the pipe and manifold in your second picture. Somebody else used a bi-metal(like a £1 coin) foreign coin, but it disintegrated and cost a fortune to put right #-o
chipvan
Post by chipvan » Fri Apr 16, 2010 6:37 pm
cool,so is there a need to block 1st pic as well?
Thanks for the reply , a job for this eve!!
chipvan
Post by chipvan » Fri Apr 16, 2010 8:26 pm
found some stainless and made a plate for the front one,but back palte bolds real tight and was worried that they would sheer off!
whatcould happen by only doint the front one??
Post by missfixit70 » Sun Apr 18, 2010 12:02 am
Should be ok if there are no leaks in the pipe/valve or at any of the welds. Fitting 2 plates is just belt & braces really, or if you know there's a leak in the system (leak to atmosphere rather than leaking through the valve)
chipvan
Post by chipvan » Sun Apr 18, 2010 6:14 pm
ahh great, just worried about those tight nuts may get garage to do the job when i have a service soon..
Post by Doone » Sun Apr 18, 2010 10:02 pm
If the valves worn etc, or it's smoking do this one (your photo): http://s723.photobucket.com/albums/ww23 ... egi005.jpg
chipvan
Post by chipvan » Sun Apr 18, 2010 10:46 pm
Thanks bud.
