Have I broken my handbrake??
Scott & Gillian
Post by Scott & Gillian » Thu Apr 15, 2010 1:45 pm
I was only playing with it a bit and the button sort of pinged off :oops:
Now the handbrake doesn't erm, brake and the button doesn't work.
Could someone please tell me how to fix it??
Perhaps this should be in the Breaking Bongos section :cry:
Last edited by Scott & Gillian on Thu Apr 15, 2010 2:14 pm, edited 1 time in total.
I'm a collector of random things. Anything. But not glitter, which is nasty.
www.random-things.co.uk
Re: Have I broken my handbrake??
Post by mikeonb4c » Thu Apr 15, 2010 1:48 pm
Scott & Sophie wrote:I was only playing with it a bit and the button sort of pinged off :oops:
Wow - what an unusual thing to happen. I reckon its either find the bits and try to reassemble them or else PM ebygum32 or tonic as they are both breaking Bongos and might sell you one. :roll:
Scott
Post by Scott » Thu Apr 15, 2010 1:52 pm
My mother always told me that If you played with it too much it would fall off, guess she was right :lol:
Apart from pulling it all apart and trying to repair it the best option would be to replace but not having done one I havent a clue where to start sorry #-o
The user formerly known as csmcqueen ;)
スコット
Post by rita » Thu Apr 15, 2010 5:43 pm
Looks like the flange on the button in knackered,needs another button.
Post by Doone » Thu Apr 15, 2010 10:56 pm
If it's not broken, try taking the plastic cover off and then relocate it in the hole.
steviebongo
Post by steviebongo » Thu Apr 15, 2010 11:03 pm
it looks like it needs another lever i'm afraid ,i just changed one on a focus for the very same thing!
cheers stevie
Post by Bob » Thu Apr 15, 2010 11:04 pm
I'd take off the trim which you remove to get the seats up, then come at it from the back.
I recon you could remove the carpet and investigate, not sure if the bit which has come out is held in by the trim at the front, or a circlip, or similar, towards the rear.
Scott & Gillian
Post by Scott & Gillian » Fri Apr 16, 2010 11:49 pm
Panic over!
I undid the trim and found that the other end of the rod - that the button screws in to, had jumped out of the ratchety bit!
Bit fiddly getting it back in place though it was more a matter of luck than skill I think!
